I always see a grey R33 GTR with lots of nismo badges in the Findon shopping center carpark. Has vented front-guards and the rims don't quite match up with the guards, but otherwise seems fairly tidy.
Guessing someone on here?
Yeah I see that 33 regularly also Jenna. So many nit wits in that carpark I've seen some very questionable displays of parking haha!
On edge that could have been me you spotted grange rd I turned onto south rd. Just got the car back with my greddy induction installed... I realized I got usernames mixed up the other day it must have been zed x I saw early in the morning a while ago. No wonder you were confused haha
I've been in that carpark pretty much daily for the past 6 years. I've seen some of the worst parking in my life there. I try and not park near people if I can help it. Half the cars are parked across lines, at angles, and other nonsense. It seems worse on particular days of the week too. Think it must be pension day or something ..
True. Alongside grange rd is good cause people are too lazy to walk 50m and the parks are wider. I always try to pick a park where only one car can be next to mine so there's half the chance of random damage.
Prob was u, thought it was anyway.
I know that 33 too think he got inspiration from my car but failed miserably in execution, an it aint a gtr
You spotted me? Hmm when was this lol?
I did spot a nice silver 32 gtr pulling onto churchill from regency earlier on this week, was around 6am.
About a week ago on holbrooks rd, about 6 am aswell. :action-smiley-069:
Was most likely me you saw on churchill, part of my daily commute. I love dropping it down to 2nd coming down the bridge and hugging the slip lane onto regency already doing 60 that time of morning (not while the roadworks are there like they currently are)
Ah yea I thought it might have been you ;)
Haha yea you were definatly flying through when I spotted you. Sounded amazing coming into 2nd under high revs :)
I pass through there around 5pm, some people are so slow through there. Just sit in the intersection like a douche -.-
spotted plenty of skylines today in the ne suburbs -
silver 34 gtt sedan, looked very stock @ repco modbury around 10am
black r32 with big wheels on NE rd st agnes around 10:30am, pretty sure it was a GTST
navy blue r34 gtt sedan, looked stock besides exhaust, in front of me around the same time as above
white 33 gtst near TTP
black 33 on lower NE around midday near highbury tavern
and a black 34 gtt coupe on lower NE coming out dernancourt shopping centre around 4:30
Near tapleys/ grange intersection on grange road at night
not there it wouldnt have been. thurs and fri nights i was down around semaphore / taperoo / osborne area (military rd, lady gowrie drive and victoria road)
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
