Spotted kahli near thebby theatre today and I think Cosi came past my street around 4pm. Also while at autobahn mile end this arvo I heard a really nice rb clearing it's throat, it was a silver stag turning onto sir Donald bradman. Sounded good.
yeah that would have been me :cheers: was on the way to cbc to grab some parts for my brothers 34
Spotted a 34 kinda stock looking driving down anzac highway this morning around 9:50 ..It was hanging out for a wash :banana: lol
Parked white 32 GTR near auto barn mile end :yes: neat as !
My GTR out the front of my work :)
