i have a r32 gts-t ti has 3 inch cat back exhaust,pod filter, strut bars, coilovers. wondering what mods can i do to make it faster iam getting fmic soon whate else ?? wanting to boost it some time too...i was think myabe a full exhaust system next?? what you guys think
https://www.sau.com.au/forums/topic/205833-r32-gts-t-mods/
Leave the catback on and change the dump pipe to a larger one, 3" pipe should be fine.
Install a FMIC but nothing too big other wise you can loose power.
Upgrade ECU
Install a boost controller to run a few PSI higher but if ya wanna run HIGH boost you will have to upgrade internals.
Another thing is lightweigh the flywheel. No power gain but you can take off quicker.
BTW if ya wanna get anal about cooling, after installing your FMIC you can install water jets to spary onto the intercooler once the car hits boost to soak out the heat on the FMIC. Mind you topping up water will be frequent. LOL!
OR install a Supercharger for low down revs / and turbos take over when boost kicks in. = Thats a BIG job and mainly for race/High performance applications and it has been done before in Japan. R32 GTR Supercharger Twin Turbo.
Edited by (00)SKYLINE(00)
https://www.sau.com.au/forums/topic/205833-r32-gts-t-mods/#findComment-3642767
Upgrade ECU
ok yes so what size intercooler would be perfect??? and will it fit the standard front bumper ??? or will i need to custmoise the bar?? after the fmic i will get a dump pipe and high flow cat then boost controler
https://www.sau.com.au/forums/topic/205833-r32-gts-t-mods/#findComment-3643498
i had a 600x300x76 size intercooler on my 32 and didn't have to cut the reo up, just had to skim a fraction off the frontbar itself at the bottom.
https://www.sau.com.au/forums/topic/205833-r32-gts-t-mods/#findComment-3643516
^^Yeah thats it thanks!!!
TYPE 2 INTERCOOLER KIT FOR SKYLINE R32 GTS-T
COMPLETE KIT INCLUDING PIPING, HOSES AND CLAMPS
600 X 300 X 75 - INCLUDES POLISHED PIPING
PRICE: $595.00
Found this on the Unique Autosports Online Catalogue Advertised at http://www.300zx.com.au/pricelists/priceli...ylineturbos.htm
Quote "after the fmic i will get a dump pipe and high flow cat then boost controler"
Well ya prety much set. That will get you abit of power under the hood. Take it easy too :)
https://www.sau.com.au/forums/topic/205833-r32-gts-t-mods/#findComment-3644243
k what if i don't get a front mount will that restrict a lot of power??? what if i upgrade my side mount is that the same?? cause front mount cops will defect me wont they??
You still can get a FMIC but make sure you don't loose any boost presure. If ya front mount is too big presuer loss can happen and end up loosing power while running standard boost.
600 X 300 X 75, if this size intercooler is still OK for standard boost then go for it, if not upgrade the SMIC.
https://www.sau.com.au/forums/topic/205833-r32-gts-t-mods/#findComment-3662330
ummm, how can you loose boost pressue from a fmic? the wastegate is controlled by pressure so if you have less pressure the wastegate won't be open so the turbo will spool up more until it gets to that pressure.
the only way to 'lose pressure' is if you have a very restrictive cooler and have the wastegate gets its pressure reading from before the cooler and have your gauge after the cooler. this will make it so the turbo is still running at normal pressure, but due to the restriction in the cooler the engine isn't getting as much air.
https://www.sau.com.au/forums/topic/205833-r32-gts-t-mods/#findComment-3662375
+1 for 600 x 300 x 75.
+1 for front pipe, etc.
I wouldn't worry about water cooling your intercooler unless you live in the Gobi desert. My FMIC is mostly cold to the touch even on hot days. But like (00)Skyline(00) said if you wanna be anal it's an option.
https://www.sau.com.au/forums/topic/205833-r32-gts-t-mods/#findComment-3663355
the majority of intercoolers need a hole cut under the battery tray to pass the piping through.
This is illegal and (according to law) affects the structural integrity of the car, if police find the hole, it will be a costly to fix. (lets hope you dont live around Knox area :banana: )
Companies such as Blitz, ARC etc produce return feed intercooler's which use the same piping holes as your standard SMIC, so all legal :dry: Expect to pay $800+ for these branded intercoolers.
Or you can either buy a R34 SMIC customized to r32 or find a ARC SMIC.
I have a r34 smic customized for r32 for sale, pm sent if interested :spam:
Cheers
https://www.sau.com.au/forums/topic/205833-r32-gts-t-mods/#findComment-3663801
ok iam gonna buy my exhaust soon from gktech so i need
a dump pipe+front pipe+high flow cat
or
dump pipe+front pipe+ de-cat pipe
get a single chamber front/dump pipe combo.. saves having an extra gasket for nothing.
i wouldn't advise getting a decat pipe unless you're game.. cops don't like them too much :thumbsup:
my opinion, go with a highflow cat. if you are interested in getting a decat pipe pm me.
https://www.sau.com.au/forums/topic/205833-r32-gts-t-mods/#findComment-3664164
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
