hi all,
As some of you may or may not know the SAU VIC AGM is coming up in mid March and the new Committee is elected.
This is important for all members as you have a chance to make a decision for the clubs direction and future.
If you haven't already read the nominations and current positions available you should familiarize yourself for these.
Voting is only eligible to current financial members of SAU VIC and voting will be done for all nominated positions on the night of the meeting.
For current nominations, information and listings of the official roles please check out
http://www.skylinesaustralia.com/forums/20...it-t203698.html
Note: this is only available to SAU VIC members (paid membership)
Vote #1 - R31Nismoid (Ash) for President
I stand by Ash running for president for 2008/09 calendar year and believe he will do a great job.
I believe he has the clubs background, the clubs foundations, its member base and extensive knowledge of what's worked in the past and what hasn't.
For this I believe he is the most suitable candidate and he has my vote as President.
I would love to stand by and support as Vice but I am unable to commit my time due to the other personal commitments.
This isn't to say the other candidates are not suitable - you should make that decision yourself on who is suitable - this is just my "campaign".
This is not propoganda - just expressing my support
https://www.sau.com.au/forums/topic/205944-the-presidents-campaign/
i was gonna vote justin911....but ok ash got my vote
hehehe...i can just imagine ash's thankyou speech after winning:
".....and I vow to make the search feature more user friendly for everyone to enjoy.........."
Hmmmm
I see where this thread is going...
You two need to cut to the chase and get it over with. It is valentine's day tomorrow.
Is that you on the left James? The guy with the hard on?? call me sometime, your hot :)
yes... i was joking... please no more gay porn on SAU, at least put lesbians.....
erm.... thanks for the unexpected support there Paul and others, or lack thereof.
I do live in Windsor don't forget, h0m0 pic's are a part of daily life... :sorcerer:
Dunno what else to say, kinda didn't expect to see a thread about me running for Pres he he...
Hopefully the AGM gets a big turnout and the view of the members is reflected well in their choices for Exec positions, as that will be the best possible outcome i hope.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
