So i need to replace the gaskets on my TD-06 L2 20g to finish off the rebuild on my RB20.
Im having trouble finding anyone that stocks or can get a hold of the gaskets and just wondering if anyone has replaced theres before and who did they go through???
I need:
manifold
manifold to turbo
turbo to dump
Any help appreciated
Cheers Ben
PS: i know this is now in 2 sections but had no replies so far and i know guys like Troy, James and Silvergtst are running the same turbo :D
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/
I had the biggest prick of the time trying to find a manifold to head gasket to suit RB20/25.
I have the part number and called NISSAN and they want between $103 - $115 which I thought was a rip off so ended up ordering it through RHD JAPAN.
About $71 incl air mail express delivery to my door, which is pretty good considering the prices here.
Part #14036-21U00
https://www.rhdjapan.com/home/products/prod...roduct_id=3277#
As for the other gasket any good local exhaust shop should have them.
Good luck.
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/#findComment-3647717
i got a few, i found :ninja:
sorry bout other day comp dropped out :(
email me your addy and i will arrange to send them $30 for the two trust ones. Call MD Spares in moorabin for your head to manifold gasket.
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/#findComment-3649419
i got a few, i found :(
sorry bout other day comp dropped out ;)
Email sent :ninja:
Will get onto MD Spares on Monday
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/#findComment-3649774
  • 1 month later...
Autobarn....that's where I got my ones
Hey Dan
my local Autobarn couldn't help me as "i" didn't have the part numbers, as you would see Trent replied last month about having them but i haven't heard back since transferring the money so the search continues so i can finish the car.
I will call a couple of the AB stores in Melbourne/Sydney tomorrow and see if they are able to help out further.
Cheers Ben
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/#findComment-3759142
GCG have the gaskets... call them..not cheap though.. i think around the $50 mark for a dump gasket... you can use ur old one with some glue... or ifyour flanges are real smoothe and rust free just use exhuast seals and no gasket...
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/#findComment-3759523
Hey Dan
Cheers Ben
WTF????? i have not recieved your money and we even called and SMS'd to see if you still wanted them, with no reply................... they are still here waiting in the same spot.
I take offense to the above greatly. If you have proof of transfer (im assuming wrong acc) let me know or at least call me 0419 590220 if there was a problem
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/#findComment-3760565
WHAT????? i have not recieved your money and you did not reply to CATS calls or SMS................... they are still here waiting.
Transfered 29/2/08 01:27:19 pm, receipt number: N022986488721
I replied to the sms and also sent you a couple of emails but didn't hear anything :( .
Just checked again and the account details are correct (from sms) so you should of received it, no biggy though i just need the gaskets to finish the car hence trying to source them elsewhere.
Not having ago at you or Cat just want to finish the car Trent and figured you guys have been busy :(
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/#findComment-3760590
I think you should send the Pringles as well, a show of good faith
No need for good faith, just some crossed wires so it looks :rant:
BUT i do have the munchies a little after finishing work and some pringles would go down a treat :)
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/#findComment-3764237
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
