Hey lads,
I've got some stickers on the boot and left and right fenders that i want to get rid of, they're kinda old looking.
What's the best/safest method to do this? I heard a blowdryer and some kind of solution will do it?
Thanks in advance.
https://www.sau.com.au/forums/topic/206310-removing-stickers/
what i used on mine was a hair dryer, then the stickers came off easily, but had a little bit of a sticky residue left, and a guy told me to use 'wax and grease' remover, and it worked a treat and didnt heart the paint..
Hey lads,
Thanks in advance.
that's right, just use blow dryer and pry them off with your fingers or something that's solid but won't scratch the metal surface
sticky residue you can take off either with blow drying again and smudging it off slowly or methylated spirit
a citric based adhesive remover available from Bunnings. It smells like oranges and may even have orange something in the name can't remember but it is the best, completey non-toxic and won't damage anything... it so good it will remove windscreen sealants from stuff as well, no problem...
Listen to the man! Tried it to get the sticky stuff left over from my old service sticker off, worked a treat!!
A word of warning with citric adhesive remover- it marked my clearcoat.
Blowdryer worked good and the stickers are off, but i'm not using the adhesive remover for any more of the glue.
What about metho or wax & grease remover? Are they gentle on the clearcoat?
I'm not fussed about the paint, it looks as though a professional detailer can just polish it out :whistling:
Thats interesting that you say it damaged your clear coat cause it's just orange juice, that would mean you don't need brake fluid to stuff peoples paint jobs just some juice...
I've never heard of it damageing anything, in fact we use it to get adhesive off clients cars all the time...
i have that problem....the stupid dumb japs left it on my car and never wiped it off....on my front left quarter i have drop spots......not happy....essentially took it back to the bare metal....oh well....as long as i seal it over for now it wont rust.....
as for the sticker removal....im gonna do that 2moz.........hair dryer and metho....and while im there...take off the other stickers on the inside of my windscreen.......
Metho is completley safe for car paint. i use it everyday on cars at work to prep for sticker application. not really ideal for removing the glue, bug and tar/citric based stuff is best. just roll the glue with your thumb and it should come off.
if you get the heat just right with your hairdryer u wont leave behind any glue anyways.
Edited by sivart
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
