Hey lads,
I've got some stickers on the boot and left and right fenders that i want to get rid of, they're kinda old looking.
What's the best/safest method to do this? I heard a blowdryer and some kind of solution will do it?
Thanks in advance.
https://www.sau.com.au/forums/topic/206310-removing-stickers/
what i used on mine was a hair dryer, then the stickers came off easily, but had a little bit of a sticky residue left, and a guy told me to use 'wax and grease' remover, and it worked a treat and didnt heart the paint..
Hey lads,
Thanks in advance.
that's right, just use blow dryer and pry them off with your fingers or something that's solid but won't scratch the metal surface
sticky residue you can take off either with blow drying again and smudging it off slowly or methylated spirit
a citric based adhesive remover available from Bunnings. It smells like oranges and may even have orange something in the name can't remember but it is the best, completey non-toxic and won't damage anything... it so good it will remove windscreen sealants from stuff as well, no problem...
Listen to the man! Tried it to get the sticky stuff left over from my old service sticker off, worked a treat!!
A word of warning with citric adhesive remover- it marked my clearcoat.
Blowdryer worked good and the stickers are off, but i'm not using the adhesive remover for any more of the glue.
What about metho or wax & grease remover? Are they gentle on the clearcoat?
I'm not fussed about the paint, it looks as though a professional detailer can just polish it out :whistling:
Thats interesting that you say it damaged your clear coat cause it's just orange juice, that would mean you don't need brake fluid to stuff peoples paint jobs just some juice...
I've never heard of it damageing anything, in fact we use it to get adhesive off clients cars all the time...
i have that problem....the stupid dumb japs left it on my car and never wiped it off....on my front left quarter i have drop spots......not happy....essentially took it back to the bare metal....oh well....as long as i seal it over for now it wont rust.....
as for the sticker removal....im gonna do that 2moz.........hair dryer and metho....and while im there...take off the other stickers on the inside of my windscreen.......
Metho is completley safe for car paint. i use it everyday on cars at work to prep for sticker application. not really ideal for removing the glue, bug and tar/citric based stuff is best. just roll the glue with your thumb and it should come off.
if you get the heat just right with your hairdryer u wont leave behind any glue anyways.
Edited by sivart
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
