hi guys,
I recently have spun a big end bearing and i just want to know how to help prevent it from happening again.
These were the mods when it happened:-
ACL race bearings
N1 oil pump
blueprinted bottom end
Castrol 5w-30
Is there anything i should do or is it just bad luck/motor not put together probably
cheers Tom
https://www.sau.com.au/forums/topic/206613-r33-gtr/
  • Replies 49
Getting a baffled sump will only help with keeping your oil cooler (but upgrading to an aftermarket sump will generally mean higher capacity which is a good thing) and your problem has stemmed from lack of oil.
The simple fix is to overfill your oil 500ml - 1L above the full marker but this is generally just a precaution for track going vehicles.
considering your car is street only id be wondering if there was some sort of blockage or your oil pump failure. This really shouldn't occur on a street only car.
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655137
Sorry, but you have missed the point of having a baffled sump - The point of the baffles isn't to keep your oil cooler, but rather to prevent oil starvation under hard cornering/load, which is particularly common at the track.
Ideally, anyone building an engine should be at a minimum fitting sump baffles, a good quality oil cooler, and an upper oil gallery restrictor.
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655278
what oil should i be using to help prevent this happening again??? also would keeping the oil cooler help. what temperature should it be at??
Yes, keeping the oil cool is a priority.
Which oil you choose depends on your engine and its condition.
If the oil gets too hot, it gets too thin and you will run the risk of spinning a bearing again.
Personally I run Motul 300V Chrono, however given that my GTR takes 10 litres per change with my larger sump and cooler setup, it makes for expensive oil changes!
An oil cooler really is a must have on a modified GTR.
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655326
IMO - Baffles - waste of money as its only fixing another problem indirectly.
For a street GTR, with the RIGHT head modifications to stop the oil starvation in the first place... negates the need for a sump.
Heavily tracked GTR's here (350rwkw style) ran stock sumps without problem, so can you for a street car :)
Read the FI Guide (its a sticky), and in there it contains a link for Oil Control in RB's.
If you get that right, and have it rebuilt correctly, there is no reason it should die.
I would say your motor either wasn't assembled correctly or you ran low on oil at some point possibly. Likely bet is motor assembly.
Castrol 10/60 is what i would be using in a built motor personally, been run in all of mine for the past 4 years, no issues
5/30 is probably part of the issue
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655372
what power are you putting out?? what rods are you using? what rod bolts/studs are you using??
pushing big hp on stock rod bolts "can" stretch and lead to big end failures, although oil control problem are common in gtr's as stated
A spun bigend on a 20k km built engine driven on the street = something very very wrong
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655410
Detonation/pre-ignition is probably the biggest killer of conrod bearings on GTR's when the boost is wound up. Most of the time you'll find there's no oil pump problem etc.. Have a look at the other conrod bearings, if they have marking on the upper bearing from 10 thru 1 o-clock it's usually a good sign of detonation. It happens because the mixture fires too early and the piston is pushed back down the bore while the crank is still trying to push it up, this squeezes out the oil film and you have metal on metal contact between the crank journal and the bearing.
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655710
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
