Spark Plugs
Guest kirby_armstrong
Just decied to change the plugs in my R33, and got a pretty big shock (no pun intended) when I got some prices on the Platinum plugs, It already had AUTOLITE AP 392-11 plugs in it. I cross refenced it with NGK and got the part number of pfr5g-11 ($20.99ea) for the platinum ones and BKR5EIX-11 ($21.99ea) for the iridium,
Question???
Whats the difference between them other than price.
And can anybody get them cheaper any where else????
I am also chasing a HKS or Trust Dump pipe for a R33 GTS-T I've rang JMS and Just Jap and they dont have any brands that I know.
Thanks for your help guys
https://www.sau.com.au/forums/topic/2070-spark-plugs/
Guys from my understanding and talking to the fools at the local auto shops, I though that the platinum plugs were better than the iridium plugs, and that the iridiums were marketed for dunnydores that wanted better than copper, but couldn't afford a better car or plugs??
So I guess the question is, which is better, which is more expensive and which is better in a turbo skyline?
maybe we could have some suggestions from users of both, that might help the rest of us when paying for $20 plugs
(At least we don't have to get "performance leads" ahahahahaha)
https://www.sau.com.au/forums/topic/2070-spark-plugs/#findComment-38350
hitnrun,
I looked into it also, some boring nights at work i tell ya.
The iridiums are NGK's better plug, but they only come with a fat gap (1.1mm)... thats where I am having problems with it missing at the moment.
The iridiums rrp is ~$21 and the platinums are ~$18... but, i'll be going back to copper with a 0.6mm gap.
The iridiums were fantastic when new, the car idled better and was different when cold, but now they are just **** (well, i hope its the plugs causing the problem)...
Anyway, not very informative, but thats me! :P
Christian
https://www.sau.com.au/forums/topic/2070-spark-plugs/#findComment-38401
NGK Iridium’s / Platinum’s / Copper’s
I've tried the odd plug in the near on 3yrs of GTS25t ownership & after being told by a few different local suppliers of NGK plugs that they didn't have a 7 heat range iridium to suit my application I decided to settle on VX's, which have been bloody excellent to date!.
Why 7's you ask? Well, as per the NGK US site, it’s recommended that for every 75 to 100hp (fly) above stock you go 1 heat range colder. So take the RB25DET from 250hp to 400+hp & it's a good idea to go to a colder plug, hence I now run 7's. Read this info - http://www.ngkspark.com.au/spark_plug_tech_tips.htm
So for those that wish to use iridium plugs but want a 7 or colder plug what do we do? Luckily NGK have a racing application plug labeled IRIWAY, i.e. IRIWAY7, IRIWAY8 & so on depending on the required heat range. These plugs aren’t likely to be stocked on the shelf so you’ll need to request them via special order. They cost ~$25ea.
There’s no problem with using copper, platinum or iridium plugs so long as you replace them as required. Naturally the better quality materials mean the plug will last longer (copper will wear quicker) but as long as the spark is strong enough to ignite the mixture, & most importantly the plug is the correct heat range for the application, then all is well. : )
I'll be giving the IRIWAY7’s a shot next time I do a plug change.
On a final note, I recall a test done in an old issue of FF&R’s where they tested a range of different plugs on the same car/dyno etc… The humble old coppers made the most power! Cheapest plug for the biggest power gain. Mind you power isn’t the only aim of a good plug.
My 2.2c
https://www.sau.com.au/forums/topic/2070-spark-plugs/#findComment-39304
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
