Spark Plugs
Guest kirby_armstrong
 Share
Just decied to change the plugs in my R33, and got a pretty big shock (no pun intended) when I got some prices on the Platinum plugs, It already had AUTOLITE AP 392-11 plugs in it. I cross refenced it with NGK and got the part number of pfr5g-11 ($20.99ea) for the platinum ones and BKR5EIX-11 ($21.99ea) for the iridium,
Question???
Whats the difference between them other than price.
And can anybody get them cheaper any where else????
I am also chasing a HKS or Trust Dump pipe for a R33 GTS-T I've rang JMS and Just Jap and they dont have any brands that I know.
Thanks for your help guys
Guys from my understanding and talking to the fools at the local auto shops, I though that the platinum plugs were better than the iridium plugs, and that the iridiums were marketed for dunnydores that wanted better than copper, but couldn't afford a better car or plugs??
So I guess the question is, which is better, which is more expensive and which is better in a turbo skyline?
maybe we could have some suggestions from users of both, that might help the rest of us when paying for $20 plugs
(At least we don't have to get "performance leads" ahahahahaha)
hitnrun,
I looked into it also, some boring nights at work i tell ya.
The iridiums are NGK's better plug, but they only come with a fat gap (1.1mm)... thats where I am having problems with it missing at the moment.
The iridiums rrp is ~$21 and the platinums are ~$18... but, i'll be going back to copper with a 0.6mm gap.
The iridiums were fantastic when new, the car idled better and was different when cold, but now they are just **** (well, i hope its the plugs causing the problem)...
Anyway, not very informative, but thats me! :P
Christian
Christian: actually that might not be right.... john P mentioned last week when i tried to order HKS plugs for my car that iridiums now come in a 0.7mm gapped unit.
I was going to use 0.8mm gapped iridium plugs.
NGK Iridium’s / Platinum’s / Copper’s
I've tried the odd plug in the near on 3yrs of GTS25t ownership & after being told by a few different local suppliers of NGK plugs that they didn't have a 7 heat range iridium to suit my application I decided to settle on VX's, which have been bloody excellent to date!.
Why 7's you ask? Well, as per the NGK US site, it’s recommended that for every 75 to 100hp (fly) above stock you go 1 heat range colder. So take the RB25DET from 250hp to 400+hp & it's a good idea to go to a colder plug, hence I now run 7's. Read this info - http://www.ngkspark.com.au/spark_plug_tech_tips.htm
So for those that wish to use iridium plugs but want a 7 or colder plug what do we do? Luckily NGK have a racing application plug labeled IRIWAY, i.e. IRIWAY7, IRIWAY8 & so on depending on the required heat range. These plugs aren’t likely to be stocked on the shelf so you’ll need to request them via special order. They cost ~$25ea.
There’s no problem with using copper, platinum or iridium plugs so long as you replace them as required. Naturally the better quality materials mean the plug will last longer (copper will wear quicker) but as long as the spark is strong enough to ignite the mixture, & most importantly the plug is the correct heat range for the application, then all is well. : )
I'll be giving the IRIWAY7’s a shot next time I do a plug change.
On a final note, I recall a test done in an old issue of FF&R’s where they tested a range of different plugs on the same car/dyno etc… The humble old coppers made the most power! Cheapest plug for the biggest power gain. Mind you power isn’t the only aim of a good plug.
My 2.2c
 Share
    • Hi guys, I have a 2005 V35 skyline with the vq35de.  It is a drift car and has been stripped, its now running a standalone ECU and a body harness. Dash everything has been changed to a digital dash controlled by ecu.  The vq35de has been great, very reliable but wanting more HP atm the 35de is making 228rwhp. I'd like to be making about 350rwhp. From my research it looks like a vq25det lightly modified could be a good engine to swap in. I understand the CD trans will bolt up right to the vq25det with a 35de sump used.  My only issue is a wiring harness/ecu to control the vq25det, from what i've found the ecu is a lot different to the vq35de so my plugin for the 35de will not work. Is there any potential to use the vq35de wiring harness and modify as necessary to retain the plugin ecu?  Keen to hear what you guys think, or am I best off to chuck on a cheap turbo kit on the 35de and see how long it lasts.
    • Oh sorry Justin! I was racking my brain trying to remember names, not sure why I associated “Adam” with 7tune! I’m good, been away from Skylines for over a decade, got family and kids now. Just getting back into owning a 32 but it’s a whole different world now… tax is higher and tech is better.
    • Who's Adam? Hehe 😁All good mate, it's Justin. Been good! And you? The HCR32 is looking sweet by the way! Love the very neat Nav install.  I would love to get one but I'm at a crossroads right now and can't commit to another car.
    • Wtf. $1000 for knockoffs? Tell em they’re dreeeeamin!
    • zomfg @Rezz! How've you been Adam?? Haha sadly yes it's going up for sale, just tidying it up a bit and modding it ever so slightly so I can still drive it to SAU events.
