Hi,
As the title says I am trying to choose a sway bar combination. I have been looking at SK's group buy whiteline stuff and noticed that the adj sway bars are 24mm front and rear.
On greenline’s website the nismo ones are non-adjustable and are 27mm front and 23mm rear. I don’t mind the rear being a little softer but is 27mm at the front just too big? Would you be able to adjust a 24mm bar to be as tight as a 27mm one?
My car is a R33 GTS-T which is trying to be a track car (well one day, eventually, maybe :dry: )
Anyone with some first hand experience would be great.
Cheers,
Ryan
https://www.sau.com.au/forums/topic/207095-nismo-vs-whiteline-swaybars/
just found this.
http://www.skylinesaustralia.com/forums/Sw...=nismo+swaybars
If i read it right the whiteline front adjustable ones will be as stiff as a nismo one when adjusted all the way across?
And visa versa with the rear?
If you're going to track it the ability to tune front/rear roll stiffness (which will help you balance understeer/oversteer) will be pretty useful. I'd go for the whileline adjustables.
Mate there is little point getting a Nismo one as the locally produced ones are just as good. Plus if you are going to track it def go the adj ones as you can easily tune your setup to suit the track on the day.
whatchya mean craig? couldn't get the link down to the last holes or were you worried about the angle once you got it there. or does it foul on something?
the trick to installing sway bar is that the car has to be level left to right both front and rear when you try and fit it, otherwise the sway bar does exactly what it is designed to do - put pressure on the opposite side. If you cant get the car level jack under the lower wheel until it is level, then the bar will fit fine.
it doesnt foul on anything. as far as i can remember, and i do remember the angle it was sittiing at was a bit disturbing, it was installed a long time ago, it was giving me shit trying to get it any harder than that setting. but i have never tried installing it with all 4 wheels off the ground. still i dont see what difference it will make by doing that.
to me, driving the car up onto ramps sounds like it could work.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
