I'm still trying to find a wiring diagram of R33's that show airbag wiring, but i can't track one down, can anyone help?
I'm pretty sure just pulling the fuse should be enough Ant... But if you want to disable permanently since you do most of your driving on the track, then maybe you should unplug the airbags completely, it's pretty easy i can help you out if you need.
I'm looking to replace mine but not hook it up, Airbags scare me now. And it wasn't even me driving!
I've checked the docs I have with me and can't find a wiring diagram...will check at home as well.
Yeah even though most of the driving is done on the track I still drive it to events as well as the fact I still take it on drives every now and again. If the laws said both driver and passenger could legally use a harness on the street I wouldn't worry but as we are forced to use the normal seatbelt, I'll want to keep the airbags. Hence I want an easy way to disable and re-enable the airbags.
I've always looked at the airbags and thought it would be a bitch if they went off during an accident on the track but never even considered them going off at random! Like I said in my first post here...I'll have to add that to the list in the back of my mind.
You can legally wear a harness on the street! You just have to wear your normal seat-belt as well. :(
Personally I always just wear the harness on the street because it fits me better in the race-seats than what the standard seat-belt does.
Lol...how stupid is that?! :laugh:
Thanks Neil....thats what I was thinking of doing but until then I was looking for a simple solution re: the fuse.
Sorry mate....I had a look and the diagram I have was just for the coilpack loom that I had from a while ago. If you do manage to track down a full one or one that relates to the airbag I'd appreciate a 'copy' :P
Snowman: did you hit something/bottom out etc?
I have been trying to decide if I should ditch the airbags or not. I was keeping them in, since I thought they probably wouldn't go off unless I was in a big one (pull lots of G's in right direction). I also thought that they would be nice to have since they help decelerate your head.
The opposing view is that since you're in a car with a cage and in a harness, the timing of the airbag will be all wrong (I think you arrive later than the car expects due to lack of interia reel etc). I am also worried that if I clip a serious corner that they'll go off, rendering me blind for an instant (stun from explosion sound etc) and send me off into the greenery..
Has anybody seen any documentation showing that they are bad for motorsport? I always assumed competitors pulled them out of the cars as they are heavy (my passenger bag weighs 4kg).
Cheers,
Scott.
Scott - I didn't clip/hit anything. I had just pulled out of a slide on a skidpan but I was just straightening up when it went off and I really wasn't going fast at all (like I don't think I was even going fast enough that the airbag should have deployed even if I'd crashed straight into a tree).
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
