Radiator Air Deflectors, New Group Buy (no 5)
I'm interested, but in the middle of a GTR front end conversion for my R34 GTT... What are my options then chief???
  • Replies 113
HEy all.
Current list looks like this..
STAGEA Series I
Xmetal
STAGEA Series II
None
R33 Series I
_Scotty_ (Bare)
rd-runr (Bare)
Scadtional
H@ME
reflexman
Krishy
Dan_AE86
R33 Series II
SkyKC
bnew
Silver_R34_GT-T (Bare)
Rhinorebel (Bare)
cjpwrx
t.head_wood
STRYKR 33
sfrizza
typevu
ToMMaH
GtstCoupe
Pauly33GTS-t
bryno
inthisglass
R33 GTR Series III
None
R34 GT-T STD BAR
mr_tea_pot
Hopeyz
yld34t
jrm
fishy
Howie
uncouth32
putraged
viet_boi
jeffboyracer
R34 GT-T Nismo Bar / Series II
Magic
lastarfighta
wisey18
charlie22
R34 GT-T Aftermarket bar
Icy
Thanks for the update bass junky.
Just a correction... mine is a R34 GT-T Nismo Bar not a R34 GT-T STD BAR.
Cheers again.
Inline with GB rules about having a start & end date - this is now closed.
http://www.skylinesaustralia.com/forums/Th...Gro-t81129.html
SAU is clamping down on these GB's that never occur, never end, and so on.
PM me if you have a problem. However, before you PM me think about this.
A group buy, is a group of people buying the product together to lower the price.
Buying single units here and there is not what constitutes a GROUP BUY
Thanks
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
