Hi Guys,
since i've had a rebuild... from the previous engine running lean i decided to get it checked cause,
it seemed to randomly play up, like hesitate to pickup when on boost when its been driven for a bit!
at the time i had a stock BOV.
The engine contains,
Forged Pistons/Rings/Pins
New shells/seals ect
Bores slightly honed
Polished / Flowed Head
Spitfire Coilpacks
HKS POD
FMIC
On the dyno/s I am getting readings of 12-13PSI boost…
recently added
040 pump
front pipe
new fuel filter
i went to Hyperdrive to get a dynostic, on what could be my problem causing it too run weird… anyways on the dyno I got a AFR reading of 15.## ish " the AFR went in a small down and U shaped and headed up the chart till 5,000RPM.
The guys there said its more then likely the fuel pump, so a few days later Kenzi fitted me a new fuel pump " a Bosch 040 I was told.." I drove her out and she seemed to gone fine… few days later was back into going good … until getting 2/5 hot or 30mins-1hour of driving 'mixed, accelerating and cruising'.
and between that time I put a copy SSQ BOV on between that time, and held boost better... still had the problem but!!
And yeah, this Sunday I went along to the SAU dyno day, where my ran lean, it started @ 14is AFR droped to 11.## and U shaped and started to go up to 13:## ish AFR and start to slowly wavey down the chart… but they only went from 2500-3### RPM….
Every said get a new fuel pump, but I did… and I've replaced the fuel filter and just done the o2 sensor, which didn’t really help me in any way!! Even put a new front dump on… looking at turbo blades made me :laugh: 'very white' so its differently lean!! And my sparkies are semi white / grey...
QUESTION !!! Is it true that my fuel pump needs a consistant 12v Earth? Cause its only wired to the factory wiring, and the guy who fitted tells me the rep said he provided a replacement 040 pump.. Coz changed names =S
I am so confused hey… I aint got much left to change... turbo, ecu , CAS, AFM and fuel regulator are pretty much only real things stockish not changed or serviced..!!
if anyone could help, please do!!!
Thanks
GaZ
Edited by Mr_GaZZa
https://www.sau.com.au/forums/topic/208108-r33-gts-t-running-lean-help-fixed/
Hey,
yeah "GTST", i have replaced the fuel filter about 30,000km ago, but yeah i put a new one in not long ago today... maybe its that?!
and "Guilt-Toy" i havent ever cleaned the prongs/metal things inside the AFM... was told to do it... considering i never done it since i had the car properly!!
since when can this make iyour car run lean?? and yeah Guilt... i got a OLD HKS superflower POD =/ in process of replacing!
anyone else got ideas?
Edited by Mr_GaZZa
AHHHHH
Im going through the same thing with my mates car....
Take the POD off and get a air box and also clean your AFM. there is a big chance it will richen it up.
Try it. you must try a standard air box.
let me know how it goes. do you have a air fuel ratio meter to test it ?
where are you located? i had the same prob with my mates r33, we took the pod off (hks mushroom style) put the air box back in and it works a treat now.
try it. if yours does the same thing then thats weird.... we need to find a fix for this.
can u try a standard air box for me ? and clean the AFM ? clean it with contact cleaner and i have used brake cleaner before as well.
get a real ecu and tune it
how will that solve is problem?
the stock ecu is made to go into rich mode, when the boost is increased, so something else is not working correctly. changing the ecu is just a quick bandage and doesn't really solve the real problem
Mr_GaZZa, get hyperdrive to put a pressure gauge on your fuel pump and it will tell you weather it is that or not
Edited by [Michael]
Hey every1,
they did my car today.... it was running like 1 BAR of boost!! ROFL
but yeah i still reach 12.5 AFR to about 4000RPM, then drops down to low 11's
probably the way i got my fuel pump wired, but i am going to get it 12v grounded to make it 11 AFR throughout the RPM
wasnt hhappy on the 221 RWHP it made =/ on 13PSI
:yes:
Just to answer your question Gary, factory wiring for the fuel pump isn't up to the job.
Cable gauge is to small to carry the desired amperage, causing volt drop (which gets worse the longer the distance) , which in turn means that down the fuel pump end of things its only getting ~12V instead of the ~14V it needs to run at FULL capacty.
This setup would use a relay switched by the original pump wiring, of which there will be a diagram somewhere in here.
ps. get it tuned :cool:
  • 7 months later...
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
