hey guys im about to put my motor back into my r32 gtr,
i took the box and motor out together but i have to remove the steering rack to get it out,
is their a way to put them back into gether without taking the steering rack off??
iv heard if people putting the motor and box from underneath the car, im not exactly sure on how to do this.
thx guys
https://www.sau.com.au/forums/topic/208557-rb26-removal-with-box-attatched/
to put it in form underneath remove the whole subframe then put the motor and box onto it (do up engine mounts etc). they lower car back onto subframe, bolt subframe back into chasis and voila you are done
well we've tried every way we can think of including from underneath and now always put it in thru the top. we don't have a hoist just a jack and engine hoist
but engine with box attached is a pain too, all we did was bend the radiator cross member. wrxhoon tells me it can be done though :D
Through the top I put them in seperately its easyer but you need experiance getting gearbox in but I can do it in about 2hrs this way (only bolted in not hooked up) if you have a hoist drop the subframe. undo the hicas crap lines etc undo coupling from steering col-rack, remove you waistegate actuators, put motor and box onto crossmember bolt up mounts,drive shaft/axles, use 2 gearbox lifts 1 under crossmember 1 under gearbox raise up slowly bolt up. I looked at doing it from top box attached and it look like a world of hurt to me. But if you try it let us know how you go. if you need more advice pm me.
I can only speak for a 33 GTR but you can get the engine and box in together going over the top.
You need to make sure you have a chain block close coupled (don't just try and use the engine lifter) and fit a come-along or similar with a soft sling around the gearbox to allow you to tilt it as required.
It is definitely not a one man job but can be done with some help (mine went in and out about 4 times making sure the custom top pipes fitted).
Cheers
I have alwys done it:
Box from under the car.. attach cross member..
Put engine cross member, steering rack, engine mounts and then drop engine in from the top..
Sometimes you will need to wobble a few things around (depending on whether you still have AC compressor and power steering pump still attatched).. its easier still if you remove all that and attach after the engine has been dropped in
When your finished come up to sydney and do mine too :P
i'm thinking of dropping out the bottom. lifting shell up and draging out box and engine on a trolley.
i've already undone all the looms etc, just waiting on an engine crane to get it done.
i might try take the plenum off too as it looks like i'm going to hit the hicas shit. or move that out of the way whatever is easier
yer i would if i loved putting motors in but unfortunately i hate it, im not looking forward to it
i almost ed considered paying a workshop to do it
bloody engines in & out! it's a pain in the ass , ain it?? :ninja:
something most rb owners experience hehe
i think it's easy, i just normally leave it to Mark!! actually he tells me to f##k off as i just get in the way.
mind you it''s so much harder on a road car , generally!
true, no aircon and no hicas really helps. we did it in 3 hours 2 weeks ago, + 2 more hours to strip the motor to see how much damage we had done. going back in this weekend hopefully but that takes longer (no point rushing that and finding a coolant hose under the rear of the plenum is wrong)
As long as you can lift it high enough its easier from the top and as one unit ( engine/box) . the car has to be off the ground on stands so the whole unit can fit, its a very long unit . I never remove the steering rack, the air con compreesor can be tied to the rail and the m6 bolt that holds the power steering line on the drivers side has to b e undone. Careful not to bent the cluch lines with the plenum and drop it in nice and slow while someone is watching as it is a very tight fit.
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
