Been looking at a 34 GTR and i was told it was a Vspec, but the badging is not there, are there any sure ways to tell by looking at it? It is also a chameleon purple and i am told this is a limited colour, is this true or are they just trying to make it sound good?
https://www.sau.com.au/forums/topic/208605-vspec-or-not-vspec/
Just get the number BNR34-###### off the build plate and post it in the thread called "VINS you want fasted". I have a 34 GTR Midnight Purple 2. The paint code is LV4. V-specs typically have an additional front lip under the front bar (like a black plastic sheet that goes to about half way of the engine. Also, on the rear, there is a carbon fibre sheet under the bumber that goes to just beyond the rear wheels. Good luck :D
best way is to put the chasis number through the nissan fast software a couple members on this forum have access to it and can do it for you . The other ways are the front plastic diffuser and rear carbon diffuser which did not come on the non v-spec models but can be fitted to non v-spec cars by their owners to look like v-spec's very common with the front diffuser but not the rear one because of the cost .
other ways are the speedo the numbers 1 to 3 on the tacho will be compressed with the spaceing where as the non v-spec will be normal spaceing but the speedos are very easly replaced so still be wary, other way is the rear diff caseing will be finned while the non v-spec's will be smooth same as the 33 GTR's the 32 GTR's are opposite every normal 32 GTR will have a finned rear diff caseing where the v-spec models will be smooth.
another way but iam not 100% sure the main function display on the dash on v-spec's has 7 parameters and with the non v-spec models i think only has 5 parameters maybe one of the non v-spec owners could confirm this
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
