hello all. I was driving conservatively whenh my car just stopped.There was a slight noise but i am putting it down to normal engine,gearbox and diff noise when you turn the car off and still rolling.There was a noise like a stone hitting in the front of the car and then it just stopped.I pulled over and towed home.
this is what i have found:
1)diagnosis reveiled nothing it flashed 55 (all normal)
2)no blown fuses
3)fuel pump works and there is fuel getting to the cylinder(fuel vapour when removing plugs)
4)there is spark although not sure if it is strong enough.
5)engine ust kicks over and over but not firing up
6)used diffrent spark plugs and the old set i tryied had worse spark
7)all coils tested ok(resistance test)
8)I am a little concerned about black box(spark plug amplifier or ignitor) as i am getting no circuit from one side to the other although i dont know if this is normal.
9)i have a safc installed although i doubt it has anything to do with it as i have checked all conections and all are good
Is there any other diagnostic procedure i can follow or does anyone have any technical advice
PLEASE HELP
SOS
https://www.sau.com.au/forums/topic/20907-car-just-stopped/
Hey buddy,
Sounds like an ignition problem to me. If engines just don't go like that it's usually fuel or spark and it sounds like something electrical blew. For the engine to not go at all it would have to be something common to all cylinders as you're hardly going to lose all six coil packs or plugs at once. Maybe your ignition relay blew? Might be a wiring problem although this is less likely as you'd probably get no spark at all. Also could be a amplifier problem if the earth is damaged or something? I'd be getting the auto-electrician or mechanic to my place asap. :uh-huh:
Have included a wiring diagram which may help if you haven't got it already...
https://www.sau.com.au/forums/topic/20907-car-just-stopped/#findComment-438681
The sound like a stone hitting, was it very loud? I am thinking (but hoping I am wrong) that it MAY be the timing belt? You also mentioned other noises when the car was slowing down.
Just a thought. If you get someone to turn the car over while the oil filler cap is off, you will soon see if the cams are turning.
https://www.sau.com.au/forums/topic/20907-car-just-stopped/#findComment-438836
yeah stevo this was my initial though and cams are turning.I only just changed it and thats wot i thought it was.I tested the coil amplifier and it tested out on other car as all good.I am concerned it is the crank angle sensor.Any one know the symptoms of crank angle sensor faulty?Is there something mechanical that can break in them?Why wont the car start with spark and fuel??could the timing be out due to afm or crank angle sensor fault??PLEASE HELP
https://www.sau.com.au/forums/topic/20907-car-just-stopped/#findComment-439961
pulled cas out keyway all ok.Timing belt did not slip as all cams line up on top dead centre.Heard from one person that it could be a bent rod.If so should the car still try to start on 5 cylinders??still looking for help car will go to APC if i cant work it out.
definite fuel and spark just no start
When in diagnostics checked all ok
Created a fault in afm did not pick it up
Created fault in cas did not pick it up
Created fault in coolant temp sensor picked it up
Has anyone else created a fault by pulling plug from cas or afm
to see if it is picked up on fault log??
Has anyone bent a rod in their rb25det??
https://www.sau.com.au/forums/topic/20907-car-just-stopped/#findComment-440603
hey hey.Found the problem.
After trying other computers and cas and afm and everything else
.......no compression cylinder 5
So for anyone interested you can bend me over and shaft me like i have been by this car ....although it will cost you $10 as i am trying to save some money to fix it.I just hope it is a valve and not a piston:(
https://www.sau.com.au/forums/topic/20907-car-just-stopped/#findComment-454616
ah but once again i have been shafted even harder.I removed the rocker cover to have a squiz and i found that the exhaust cam was snapped in two places just after lobe 1 each side of the cam retainer.Now thanks to kharma ,i will be in for a big spanking one from the repairer then closely followed by my girlfriend eeeek!
https://www.sau.com.au/forums/topic/20907-car-just-stopped/#findComment-455291
i dont know .I guess it is just bad luck the mechanic said that he has seen a few with snapped cams.A few meaning 3 so far and he tunes skylines and works on them all the time.The person fixing the car is the guy who tunes street machines gtr which ran 10.7 at willowbank on the weekend so if there is any one to try it may as well be him.
https://www.sau.com.au/forums/topic/20907-car-just-stopped/#findComment-455659
  • 4 weeks later...
hey qikr33..
so how much izit gonna cost u?..
cos i had the exact same problem with my r32 yesterday...
and now the engine wont start...
and when its on 1st gear...the wheel dont even spin..
really need help as my mechanic say i blew my engine...
and its better off i do an engine conversion..
engine conversion sounds good..
but money is my problem..
really need help here..
thanks,..
https://www.sau.com.au/forums/topic/20907-car-just-stopped/#findComment-499773
ok i snapped my exhaust cam in half just after 1st lobe.When charlies motors took the car they put a new cam in first and tryed to start and found that 2 bent valves and every other one was hit by piston so.....new head.The total cost is about$2300 with new head,x ray for new head and fitting and dyno tune .Car is ready in 1 1/2 weeks.I hope this helps.I dont know what u mean by the wheel wont even spin in 1st.I would get a compression guage used for testing cylinders and test each cylinder if all between 130-150 psi then all oil and compression rings ok.Therfore why a enging rebuild????But in my case if i damaged a piston it would have beeen cheaper to get a new motor put in.I hope this helps mate
https://www.sau.com.au/forums/topic/20907-car-just-stopped/#findComment-500348
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
