10sec passes!!! Ice Performance Cars shine again.
Well, well, well.
The Sunday that was!!
As Wardest posted earlier, my GTR now has run multiple 10 sec passes on street tyres!!
The best of these times was a 10.47@133mph but managed a best mph of 137 for the day which we are quite happy with. All runs were consistantly in the mid to high 130s which means that we are getting almost all we can out of the car. I ran the stock GTR suspension as the Tiens were too stiff the last time we went out.
The GTR had about 10 runs of which the times of note were:
[email protected] with 1.69 60'
[email protected] with 1.65 60'
[email protected] with 1.89 60'
http://www.yatzka.com/fajuly/hjuly01.jpg
http://www.yatzka.com/fajuly/hjuly02.jpg
http://www.yatzka.com/fajuly/hjuly03.jpg
http://www.yatzka.com/fajuly/hjuly04.jpg
http://www.yatzka.com/fajuly/hjuly05.jpg
http://www.yatzka.com/fajuly/hjuly06.jpg
http://www.yatzka.com/fajuly/hjuly07.jpg
http://www.yatzka.com/fajuly/hjuly08.jpg
http://www.yatzka.com/fajuly/hjuly09.jpg
Congratualtions to Nigel's blue twin TD06 powered Supra which ran a best of 10.91@129mph. Throughout the day, the mph were always in then 129s but never quite made it to the 130mph mark :) This will be fixed very shortly :(
http://www.yatzka.com/fajuly/hjuly11.jpg
http://www.yatzka.com/fajuly/hjuly13.jpg
http://www.yatzka.com/fajuly/hjuly14.jpg
http://www.yatzka.com/fajuly/hjuly16.jpg
http://www.yatzka.com/fajuly/hjuly17.jpg
http://www.yatzka.com/fajuly/hjuly19.jpg
http://www.yatzka.com/fajuly/hjuly21.jpg
The TURBOWORX Supra was also out there (talk bout irony)....
I think the best it pulled on full slicks was 12s at 130mph which although the speed was good, couldn't hook up for some reason. Ah well, maybe another time....
http://www.yatzka.com/fajuly/hjuly20.jpg
  • Replies 45
hehehe wardest i wouldnt have been able to hold it in if i knew too.. thats an awesome job both dave and nigel!
7000 already? sheesh and i stopped spamming aaaaaaaaaaaages ago.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
