wow- they bought that 2009 GT-R back from the future :D. lol
yes, looks like Nissan used close to the smallest turbos they could get away with for the power they wanted
US is weird. They do years of cars by model years, not actual year built. The R35 GT-R, is a 2009 model year in the US.
https://www.sau.com.au/forums/topic/209538-tiny-turbos/#findComment-3707083
On paper, the stock turbos look like they are good for about 600 hp, however we are seeing about 520 hp at the engine at 11-12 psi. The size of the wastegate is also something to consider. Its large, and the exhaust wheel is small.
For such low boost (11-12 psi) you would need a large turbine bypass (wastegate) on a 3.8 litre engine.
Cheers
Gary
https://www.sau.com.au/forums/topic/209538-tiny-turbos/#findComment-3707235
True, not only Nissan switch to IHI, alot of the Japanese aftermarket tuner's choose them... Garrett are probably able to supply them to Nissan alot more competitively than other makers. I personally would love to see the RX6B used alot more. Power Enterprise have a nice kit using it now..
Edited by MintR33
https://www.sau.com.au/forums/topic/209538-tiny-turbos/#findComment-3707361
I have Power Enterprise Turbo's on my car that are IHI, and when the mechanic saw them told me they wouldn't be much better then stock turbs or maybe similar to N1 turbos, but after a good tune, our jaws dropped from the power the tiny twins produced. Mind you , not from such tiny amounts of boost the R35 is using but non the less, they were very impressive, and at least a couple years old now. I rated IHI after having these turbs.
https://www.sau.com.au/forums/topic/209538-tiny-turbos/#findComment-3708637
These turbos are small for a very good reason :(
0-100 would not be 3.6s if they were bigger. And for the car's intended purpose these turbos are fine.
If you wanted to make an extra 150kw of course you'd put bigger turbos, or a big single (harder with a V6 i guess) but you'd lose that sharp, responsive performance i'd imagine.
I'd be interested to know how much the stockie turbos can be boosted. The Skyline turbos are sh1t for big boost, so we'll see if Nissan have done the same thing with these, as a cost saving measure perhaps.
Edited by R338OY
https://www.sau.com.au/forums/topic/209538-tiny-turbos/#findComment-3710079
I said before that they were close to a 2510 size. The inducer was around 47 mm and the exducer about 42 mm. Small overall. The car makes more power than these turbos should be able to do on paper.
R35 GT-R on Mustang Dyno
I can't post numbers yet, but Edmunds Inside Line will have numbers in a few days. On a Mustang dyno, then a Dynapack Dyno.
The car made a peak of 12 psi, and then dropped off to about 10 psi by redline.
Also, only run in 3rd gear to avoid the speed limiter that has not been killed yet. Cobb should have it any day we hope. 5th gear is 1:1.
Edited by tyndago
https://www.sau.com.au/forums/topic/209538-tiny-turbos/#findComment-3710694
I dunno what the secrecy if for....
There are numerous dyno results floating around on the net so nothing new has been done.
https://www.sau.com.au/forums/topic/209538-tiny-turbos/#findComment-3710956
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
