I am thinking about getting one of the new stealth cooling pro intercooler from Just Jap - see link below
http://www.skylinesaustralia.com/forums/Co...94#entry3707494
They use the factory cooler pipes on a r33. Does anyone know/think they would match up to the Stagea factory pipes? If so it looks like an easy install!
https://www.sau.com.au/forums/topic/209747-stagea-intercooler/
i installed an R33 ARC FMIC, slightly shorter than these, bolted up to factory pipes, might just have to modify the mounting points slightly and do a bit of hacking on the front inner metal bar. But with enough skill and patience anything can be made to fit.
I don't see why it wouldn't fit because the pipes suggest that it would fit up really easily.
I'd much rather try and get this kit to work rather than their other kit which involves drilling a hole in the chassis.
Exactly what ive been looking for, thanks for putting it up. Ive ordered one, will let you know if theres any problems but i doubt it, its all in the same place.
cheers.
Good work Momo. I think it will bolt straight up but now you will be able to tell us all.
Morgan you will have to do some mod`s to reo bar i hav just had dumie fit of blitz & had to mod reo so good luck dude.cheer`post-36964-1205209662_thumb.jpgs chuckie.post-36964-1205209578_thumb.jpgpost-36964-1205209732_thumb.jpgpost-36964-1205209804_thumb.jpgcooler size is 360x820x70.
they look good
look to be exact same size to my Apexi cooler, exact same shape etc except mine is HALF tube'n'fin and HALF bar'n'plate
Id be getting one of these intercoolers, if you want to use the same factory holes
you'll need a couple of stainless pipes tho to go from inside engine bay to the intercooler, I used a pipe kit off ebay
edit: I didnt hack anaything, bar the plastic Dayz front bar numberplate bracket (to open it up to let max air flow thru). if you install the 'cooler on a slight angle it fits without touching the reo bar
Tangles - i thought the pipes supplied would match up to the pipes used for the factory intercooler?
Do you have pics of the Dayz bar trim up - i want to do this too as the number plate bracket seems to fill half of the opening.I was concerned it might weaken the front bumper too much and i was uncertain how i would mount the plate afterwards.
Edited by MRO
oh I thought they didnt come with pipes.
nice buy if they do, thats for sure.
um, photos, none here at work
there are intercooler threads on here where Ive posted pics
just cut the dayz number plate section off (poorly cut, mind you) and bolted the number plate to the side air dam where the side mount used to be.
definately does not weaken the front area
Id like to get a small sticker number plate eventually.
i mounted my plate on the bar itself just above the original holes
Tangles, where in Adelaide are you?
I'd like to have a look at your intercooler install if you don't mind.
I've got a front mount kit coming for my RS4.
:blink:
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
