  • Replies 441
I'll meet you at thornleigh later on if you go there :)
ummm ok but i think its gonna pass your bed time ;)
Ok so are mine looking at the car or the chicks :D
I am totally bringing the camera.. coz photography is my thing :( I make cars look more sexeh :(
Well are you a babe? with huge boobs? :D
Open space James, bring ya rain jackets :thumbsup:
Hey Sheng, just a quick question, is that carpark hard to get into cause my car is abit low and i dont want to scrap my new front bar.
Also what about Castle Towers carpark coles level if it starts raing?
Its pretty empty by 7-8pm and would have to be at least 80 -100 spots
Anyways let me know
thanks
Edited by GTR32X
Anyways let me know
thanks
I just found a new place :D coz i can :), and no you wouldn't scrap, unless you car is 5mm off the ground lol
Yeah we can consider it for next time.. ill see how it goes friday :)
woooooooot.... yessum... :P
p.s Sheng can you edit my attendence from 300ZR :( .... to 33 gtst.... the 200ZR is staying at home ;)
Yessum :)
yo wassarp ppl
am only going to the meet, am not cruising lol
got overtime doing IT shit at work the next day (sat)
so cbf staying late lol. Anyways see u all there.
3rd last days before my liner say bye bye to me lol
Edited by GTL05T
I have Galston Gorge in mind atm :rofl: nice and close ( well closeish)
Then hit Maccas Thornleigh after..
I'm keen on this you POS
should head west and do Bells Line of Road :banana:
OK, no need to get loco on us essai :D
But if everyone's in...i won't kick and scream :D
woooooooot.... yessum... :D
p.s Sheng can you edit my attendence from 300ZR :blush: .... to 33 gtst.... the 200ZR is staying at home :blush:
While your changing stuff. I'm not going in my R33 anymore :w00t:
Its Gen 1 Liberty power for me! Super ugly spec :banana:
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
