Nistune Powerfc Hks Fcon Haltech Ems Link Ecu Etc Real Time Road Tune And Dyno Tune Available In Sydney And Other State
^ couldnt agree more mate!!
I love my car even more with this remap!!
Wish i did this 1.5 years ago when i was told about it lol
Just got my R32 tuned by Toshi a few days ago, very happy with the results! Much improved mid range and top end. Would easily recommend him to anyone :P
Please come to me.
I will check what type of ECU.
hey toshi
whats the story with 97 S1 RS Four Stagea
can you tune em?
  • 4 weeks later...
I wish you would come up to Brisbane.
Seems well worth it for the money.
How many people are interested in remapping?
Could have an ask around in the QLD section. GTST was one of them, could be a few more as the price seems very good.
how much for a second remap? eg get a first remap, then bigger turbo/injectors/afm upgrade, and need a second remap but already have the daughterboard installed?
Hi PWND
I sent PM.
bahanthich
I have not installed daughterboard to ECU.
Daughterboard cost is $700.
So I use H8 plcc.
This costs is $80 (can not erase)
I will make data on daughterboard ECU(real time tune) then burn data onto H8 chip.
If I install daughterboard to ECU and tune , road tune would cost $1050.
If I install H8 chip, First and second remap is same price.
If you install daughterboard $80 discount for the second remap.
Thank you
Hi PWND
I sent PM.
bahanthich
So I use H8 plcc.
This only costs $80 (can not erase)
If I install daughterboard to ECU and tune , road tune would cost $1000.
Thank you
hi toshi
can you do R34 GTT ecu remapping? I currently have only a turbo back exhaust .. but I want to get a boost controller and put the boost up to 11 and then have the ecu remapped so as to get a good/safe afr etc
What's the cost? Would a SAFC2 be a better option than a remap?
Hi Delta Force
Are you Sydney?
hi toshi
Yeah I'm in sydney mate.. By the way, can you up the boost with a remap too and then tune the AFR? I'd prefer not to have to buy a SAFC2/Boost controller if I don't have to.
Edited by Delta Force
I sent PM.
Thank you
Toshi, I live on the Gold Coast but would travel to Brisbane if you are heading this way :ermm:
hey toshi,
im interested in a tune on a r32 gtr, only has cat back, air pods, and a bleed valve, seems to run 8psi as stanadard, guess will raise to 12-14psi, what sort of torque and power levels would that give. if battery is removed from car is tune erased or damaged, where in sydney are u?
thanks mate
had my RB20 cefiro remapped by toshi, very happy with how much better the car drives. comes on boost much faster, was tuned with a safe tune because the car is primarily a track car.
for the price its defnitely worth it!!
see you soon toshi, with Z32 and Injectors!!
Hi benr32gtr
I sent PM.
Hi esky mad
I think also you need change air valve.
see you soon.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
