spotted my ex-skyline V35 coupe.......its having a bad life now :( guttered wheels so guttered i spotted them at night and terrible headlight tints and scratches on them too.
fcuk, that's got to feel bad. :-(
I hope and probably won't be seeing my V35 dirty and trashed after selling it, as I will be in Brisbane.
Spotted a silver V 03-05 model looks like at Artarmon shops rounderbout, managed a wave while turning and shifting lol, didnt see a wave back was dark tinted couldnt see inside. car looked great.
Could have been me, I'm always around that area haha
Spotted Paul's (V35_Paul) silver V35 coupe on Great Eastern Hwy near Midland area (WA) about 7:45pm on Sunday (17-07-11).
I was coming back with few friends from a cruise. I sent you a PM last week and tried to call you last night after spotting you. Did you change your number?
Anyway, hope you had a good time at 4x4 show. :)
Edited by VNS 24
Yeah i seen you guys too. :thumbsup:
Had my phone off.
Was way to busy to catch up. It was a long weekend early to rise late to bed pinch.gif
:) Fair enough.
Well, I am heading off to Brisbane soon. So I will mostly see you online.
Good luck with your V35 and everything, Paul. Nice seeing you (Twice I think) and I have enjoyed your company with WA V-series community.
Edited by VNS 24
Spotted a black V35 sedan with aftermarket wheels at the traffic lights of Shepperton Rd and Albany Hwy in East Victoria Park area (WA) at 1:10pm on Thursday (21-07-11).
I was in my V35 coupe across the road turning onto Albany Hwy. :)
Edited by VNS 24
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
