Hello illegitimate siblings :) Is this a friend of yours? Spotted it at Eastland last weekend, I do like the V35s in this colour.
Interesting find Opal...No idea who he or she is.
Its definately not Igor/Stayer..who I believe is driving all the way to the Gold Coast in his V35!
White coupe on white Volks/Rays in Ormond St Kensington on Friday night.
Looks nice, get on here and make yourself known.
Urm.. aftermarket front grill? with the Nismo wing on the rear?
Probably my friend. Guy always say he'll come but yea I'm going to tell him to come end of this month and stop being a sissy.
On another note
Spotted Yasidi on King st inbound.. just past Flinders st.
I was heading home!
I used to check this thread every day hoping to get spotted, until i realised i am one of 3 V35 Coupe owners in my town.. haha.
Same here, except I am the only V35 owner in my town.
very true, my mate owns the same V35 as me and isn't interested in the forum community. There's so much good info on this you'd be mad not to.
Also an American friend of mine made a facebook group a while ago with over 200 members, very active and great people
V35 Coupe Drivers on facebook, i'd post the link but it's blocked on my work computer! request to be added you won't regret it.
Thanks for the heads up on FB page.No big deal I've been to a few Syd meets a while ago and there are many cool V guys around. Just saying that there are many more that don't give a toss (ok too- though uncool). Your right in that you learn so much about the car here
I agree with you, i even tend to give people a wave that drive R33/34's since there's alot of them but almost never will i get one back.
I'm thankful the guy i bought the car off told me about this page, learnt a lot of things since owning the car so it's good.
Definately recommend that FB group, ask ANY question about these cars and i garauntee you you'll have 15-30 replies by the following day, realllly chilled bunch of guys and they have some insanely good looking "G's" they call them.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
