sorry to hear about it.. this happened to my bro in laws skylines after a rebuild.. the car was run in 1000km and the guy that built it put some tommie poncams in it on the side of the road outside the turners shop.... he didnt try to crank over the engine by hand and the everyones suprise when the ignition was turned there was loud bangs... long story short complete waste of a set of acl pistons as acl said should wouldent replace just one of them ( only cylinder 6) was broken.. timing was 180 out.... u guys may even remember the car... colgtsx's old r33 s2
When the engine was gettng transported we needed to close the engine up so no foreign objects got in. Which meant all the covers,harmonic balancer,timing belt ect ect were getting put on.
Paul did say that the timing belt was only put on for transporting the engine and would have to be redone when we had the engine in the car.
So in all the excitment we forgot. And after the final tune we went for a drive to see its potential.
With a tight timing belt each time i got on and off the gas the shaft holding one of the pulleys would flex back and forth, so after about 6 hrs the shaft failed due to metal fatigue, the timing belt let go,and as a result the engine went out of timing.
The pistons smashed the valve train causing bent and snapped valves,also punched a nice hole in the face of the head.
Now before everyone jumps to conclusions Paul is not responsible for this engine failure as he did tell me that i would need to re-tension the timing belt.
When i called Paul after this had happend he was very sympethetic and agreed to help me out as much as i needed to get this thing back to the way it was.
I have since bought new bearings,new valves, new valve guides,new valve seats and will be ordering new pistons as soon as i get my rego and insurance sorted.
So hopefully next month ill be driving back up to see Paul with my engine to get the ball roling again.
Yes as you could imagine i was quite guttered after this had happend, but after about a day or two i was fine.
"Shit Happens" as they say and its nothing that cant be fixed. But rest assured she will be back with a vengence very soon!
Thanks to all of you for the kind words(sound like a death in the family) lol
But especially to Paul for agreeing to go further than needed to, to help a guy out. :(
Yes i feel like every engine that leaves my workshop is one of my babies...i like to keep in contact with the owners and monitor their progress....so yes it was like a death in the family.
Dave is one of the nicest genuine fella's your ever likely to meet, so i dont mind going out of my way to help out a guy i now regard as a mate.
The engine was running like a dream making good power and had excellent oil pressure...it was just a shame an external component thats so vital to keep the engine alive let go. Ive never lost a belt/pulley/stud in any of my own or customer engines in the past when correct procedure is followed.
Damn... :)
Why not go for the RB30 with a larger turbo, ati balancer, rods and pistons and rev it to 8k with more power and the same response & spool but with more low end than the 25t with the gt30.
300rwkw is 'ok' but more power is good :P
25det all the way!
I did think of it, strapping my head to a 30 bottom. But i had a goal with this engine from the start, to make if a very efficient 25, which it was before the shit hit the fan.
At only 17psi it was making 293rwkw and it did it easy. That was only 15mins on the dyno. At the same boost level but with more tuning time, it would crack 300 no problem.
And Adam's dyno (JEM) reads lower than most.
Dave - Never about peak power. :huh:
I've been in GT30 powered rb25det's and they really are absolutely no comparison for a gt30 powered rb30det. Seriously consider it. You have the head work that will work well with the extra displacement combined with ati balancer and rods you can have a reliable 8000rpm RB30 that makes all its boost at 3k with stock turbo like transient response.
As a comparison I can sit at 60km/h in third gear with a mates rb26dett gt2510 in second gear. Foot flat mine comes up on boost holds level for a fraction of a second until ~80km/h and then storms off.
At least go for a spin in a well sorted rb30det with a similar sized turbo I think you will look at the picture differently.
Through the hills with a now sold rb25det running a gt30 .6 out of corners his noticeably lacked the instant go/torque out of the corners; I was able to sit in third gear short shift behind him. Both making the same/similar peak power but he had done the works with inlet manifold, exhaust manifold etc..
For all out drag there's really no need for the 3ltr but 'all round' general street duties, motorkhana and track work you really can't go past the all round linear power delivery of the gt30 + rb30 combo. :banana:
Checked out Al's RB30DET GT30.82's setup? Thats how yours would be given the list of extensive mods.
Problem is convincing Paul? :)
says ye who is running a GT30 and 300kw :P
Lol yeah its not good how you get used to power so quickly..
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
