If it's remotely relevant my old rb26 with 0.82 gt35 was making ~400rwkw with egt's (as measured approx 1" from the head) between 870-890degC on all cylinders after applying some pretty big corrections.
By comparison a friends rb with a t04z making a fair bit more power had egt's ranging between 860 and 910deg (a lot less work put into trimming individual cylinders). Both cars on pump 98.
Edited by DCIEVE
I think you'll find Nathan's is still a 2.6L, he will join the cool kids with the 3L's soon enough I hope
I was thinking of doing a freshen up over christmas too. maybe its time.
Thats a good result from pump 98.
Drove it to the exhaust shop today, what a feeling it was.
At full noise the exhaust sounds almost stock! Driving around in traffic its a bit louder.
Could be registered next week :)
any DB measurements or sound samples?
  • 5 months later...
Been a quite hectic last couple of months, thinking I had plenty of time to get ready for Powecruise things went a bit pear shaped after the initial run it.
More later....
Waddya tryin to build up the suspense Dave, spill it already ya beeaartch. :action-smiley-069:
Noel,
I literally need 30 mins to type the never ending saga which is my relationship with this car over the last few months.
Short hand is:
Run in.
Noisy engine bay.
Weird fragments in sump and oil
Engine out
Oil pump rebuilt
Stripped and inspected bottom end
New clutch
New harmonic balancer (modified)
New gears and pulleys (modified)
New thermo fan setup
New complete hot side :)
and a $40 alternator lol
Noel,
Short hand is:
Run in.
Noisy engine bay.
Engine out
Oil pump rebuilt
New clutch
sounds normal to me Dave. :rofl:
We sorted the last major issue today which brought a smile to my face, then one of the oil cooler fittings WELDED to the cooler decided to explode. So off to Earls in the morning to see if I can get a new cooler under warranty.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
