If it's remotely relevant my old rb26 with 0.82 gt35 was making ~400rwkw with egt's (as measured approx 1" from the head) between 870-890degC on all cylinders after applying some pretty big corrections.
By comparison a friends rb with a t04z making a fair bit more power had egt's ranging between 860 and 910deg (a lot less work put into trimming individual cylinders). Both cars on pump 98.
Edited by DCIEVE
I think you'll find Nathan's is still a 2.6L, he will join the cool kids with the 3L's soon enough I hope
I was thinking of doing a freshen up over christmas too. maybe its time.
Thats a good result from pump 98.
Drove it to the exhaust shop today, what a feeling it was.
At full noise the exhaust sounds almost stock! Driving around in traffic its a bit louder.
Could be registered next week :)
any DB measurements or sound samples?
  • 5 months later...
Been a quite hectic last couple of months, thinking I had plenty of time to get ready for Powecruise things went a bit pear shaped after the initial run it.
More later....
Waddya tryin to build up the suspense Dave, spill it already ya beeaartch. :action-smiley-069:
Noel,
I literally need 30 mins to type the never ending saga which is my relationship with this car over the last few months.
Short hand is:
Run in.
Noisy engine bay.
Weird fragments in sump and oil
Engine out
Oil pump rebuilt
Stripped and inspected bottom end
New clutch
New harmonic balancer (modified)
New gears and pulleys (modified)
New thermo fan setup
New complete hot side :)
and a $40 alternator lol
Noel,
Short hand is:
Run in.
Noisy engine bay.
Engine out
Oil pump rebuilt
New clutch
sounds normal to me Dave. :rofl:
We sorted the last major issue today which brought a smile to my face, then one of the oil cooler fittings WELDED to the cooler decided to explode. So off to Earls in the morning to see if I can get a new cooler under warranty.
