If it's remotely relevant my old rb26 with 0.82 gt35 was making ~400rwkw with egt's (as measured approx 1" from the head) between 870-890degC on all cylinders after applying some pretty big corrections.
By comparison a friends rb with a t04z making a fair bit more power had egt's ranging between 860 and 910deg (a lot less work put into trimming individual cylinders). Both cars on pump 98.
Edited by DCIEVE
I think you'll find Nathan's is still a 2.6L, he will join the cool kids with the 3L's soon enough I hope
I was thinking of doing a freshen up over christmas too. maybe its time.
Thats a good result from pump 98.
Drove it to the exhaust shop today, what a feeling it was.
At full noise the exhaust sounds almost stock! Driving around in traffic its a bit louder.
Could be registered next week :)
any DB measurements or sound samples?
  • 5 months later...
Been a quite hectic last couple of months, thinking I had plenty of time to get ready for Powecruise things went a bit pear shaped after the initial run it.
More later....
Waddya tryin to build up the suspense Dave, spill it already ya beeaartch. :action-smiley-069:
Noel,
I literally need 30 mins to type the never ending saga which is my relationship with this car over the last few months.
Short hand is:
Run in.
Noisy engine bay.
Weird fragments in sump and oil
Engine out
Oil pump rebuilt
Stripped and inspected bottom end
New clutch
New harmonic balancer (modified)
New gears and pulleys (modified)
New thermo fan setup
New complete hot side :)
and a $40 alternator lol
Noel,
Short hand is:
Run in.
Noisy engine bay.
Engine out
Oil pump rebuilt
New clutch
sounds normal to me Dave. :rofl:
We sorted the last major issue today which brought a smile to my face, then one of the oil cooler fittings WELDED to the cooler decided to explode. So off to Earls in the morning to see if I can get a new cooler under warranty.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
