dave sorry your missing something vital
Whats that?
That is what I thought :)
How about dyno tuning, who are u using for that?
See the two logos in my sig? Answered both your questions :)
Of course haha, I can't see your sig on my phone but I do remember seeing jem there on my laptop.
With over 500kw, at what revs do u expect to see full boost? I've always admired the t51r, it is king IMO! The kai would be much better for the street though.
Baking tyres on the dyno. Could only get 23psi and 6000rpm on board.
Changing wheels and tyres for more tuning tomorrow.
What an animal!!
Beast I think is a more appropriate word
Hopefully you get the numbers!!!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
