Hey guys,
As some people may know/heard the Stagea broke down the other night, had a rattle coming from the gearbox and wouldn't select any gears so i got it towed to a Transmission place. Blah Blah Blah. Got told the "Oil Pump in Transmission has blown up".
Question time:
1. Stagea gearbox is different to all other Nissan boxes being that its AWD RB25DET Neo?
2. Anyone know the Oil Pump Part No# for the Transmission?
3. Do you think you can get an after market one of these if so, where from?
Cheers,
Corey
https://www.sau.com.au/forums/topic/210419-gearbox-issues/
Hey guys,
Question time:
Cheers,
Corey
TRY WA Automatics on 94936080 ask for steve,good luck,only series 2 are different ,series 1 has A box most skylines,series 2 has B box tiptronic,cheer`s chuckie.
https://www.sau.com.au/forums/topic/210419-gearbox-issues/#findComment-3721451
the car is currently at a workshop in osbourne park, and cant find this damn oil pump info anywhere :domokun: ohhh and yeah its a 1998 Series 2 Stag with Tiptronic Box
Edited by BunkyS13
https://www.sau.com.au/forums/topic/210419-gearbox-issues/#findComment-3721476
what figures they quoting for rebuild ????
https://www.sau.com.au/forums/topic/210419-gearbox-issues/#findComment-3721553
well ive had a few updates....parts $920 ex. japan (nissan said could take upto 8 weeks to get here) so im just grabbing a gbox from a guy i know. waiting to hear back from the warranty company for them to say they will pay the Remove and Refit costs. only catch is because its a 2nd hand box they remove just the gbox from the warranty and the rest stays.
Cheers,
Corey
https://www.sau.com.au/forums/topic/210419-gearbox-issues/#findComment-3730287
Try Mike at MV Automatics is SA, he knows Nissan boxes better than anyone.
As far as I know all Nissan RWD autos are pretty much the same, minor variences only. R33GTST, R34GTT, Navara, Patrol etc
The ATTESSA doesn't make any difference to the internals of the auto, just the output shaft is different to accommodate the chain drive to the clutch pack.
Cheers
Gary
https://www.sau.com.au/forums/topic/210419-gearbox-issues/#findComment-3730787
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
