When you said changed not long ago, was it changed with a brand new unit ? or a second hand one?
These sensors are only worth 40,000km's.
If its older then that or your unsure how old it is... Change it!
seconf hand one.. should i get a new one form nissan???
  • Replies 74
Posted Images
I recently changed my 02 sensor (like 3 days ago)
Bought it from kudos..
Anyways i have noticed a big improvment in fuel economy. Also changed my plugs to the right heat range (which does matter)..
So with both these done, im getting much more KMS than before.
i just changed my dump/front pipe and when i pulled my oxy sensor off it looked very clean, no carbon build up on the bit that goes in the exhuast. this thursday i'l be going for a long drive up the coast for the weekend.
my question is, can i pull it out, spray carby cleaner on it, and use the air compressor to blow it dry ?
as i wont have time to change it till next week, and i'l be using the car alot this long weekend, will this help economy abit?
cheers
  • 2 months later...
Also don't buy cheap shitty O2 sensors. I was getting shitty fuel consumption ages ago and brought one off eBay that was compatible for about $30. It did work (kinda) according to the PFC, but fuel economy didn't improve. Then after a few months it stopped working all together. I recently brought a geniune Nissan one now I'm getting 50-70 more k's per tank. Still only getting about 340-350 with mostly city driving. I might take it somewhere else to get the tune touched up to try and improve economy some more.
guys just been through this recently, different approach but may have similar dramas. had a few small cracks in the intercooler bars on the join where they meet the entry/exit chambers( standard intercooler on r33 gtst ). was lucky to get 350km/tank not squirtin it too much, then got another off ebay in good nik whacked it in an "bob's ya uncle" bonus km's around 400+/tank (haven't had the chance to calculate 100% but you know when theres a difference).
was also expeirencing bad flat spots in acceleration climb through gears if you punched it to hard, b4 noticing the intercooler problem.
reason i highlight these points is check all things for air leaks to be on the safe side before $$$ expenditures. slightest air leak holes create big dfferences.
hope this may shed some light or kms on you fuel drainers! :(
i have also changed the o2 sensor and plugs to make sure. next thing to fine tune it is a power fc when the cash is handy :D !!!
Hi I just got a used R33 Sedan Auto GTS-T from a dealer.
the fuel consumption I think is ridiculous after reading what you guys had posted.
basically it has no mod under bonnet except a pod filter (without taking suspension, wheels, turbo timer those into account)
the first tank of fuel it used could only produce 250kms
now after spending around $150 in fuel, it can only reach 450kms (since I bought the car a week ago).
what is strange about the car is, the vacuum is blocked.
now my friend connected the vacuum to somewhere near the sensor near the pod.
and reset the ECU by unplugging the battery and plug it back.
I wonder if the fuel efficiency still has no improvement, what apparoach should I follow next?
should I.....do like what was posted earlier Aftermarket ECU + remap + piggyback?
or first try changing O2 sensor?
what's the next step.
anyone knows approximately how much would those cost?
i used to only get 260 - 280km per tank aswell but the things i did were, change the 02 sensor, change the BOV to stock, cleaned afm with contact cleaner and also cleaned my water sensor plug.
my car has the following mods (also remember that my car started out life as a non turbo as a result i have more compression than most also as a result of the compression i have a shitload more torque than others with 200rwkw:)!) whether or not this helps with fuel economy or not but eh
pfc
intercooler
ebc
walbro fuel pump
nismo regulator
full trust turbo back + xforce cat
trust pod and airbox
and a 52mm alloy radiator
i get 450km per 50L fill up (where is my last 15L? fksake) i found that changing the apexi twin chamber BOV to standard i can get 100km from 9L which is quite good :thumbsup: highway driving and shit loads of boosting whereas before id get 12 or 13...remember every litre counts
so does that mean by having a better cooling system will also affect the fuel usage?
such as radiator and intercooler
the bov which i am having is stock
and water sensor plug, afm also related to fuel usage?
seems like the PFC which everyone has, works good in this.
did you change everything at once? or you change things one by one and observe the consumption? (could you list which one is the most worth changing in the favourable order)
Three things kill fuel economy:
1. Crapped out O2 sensor. Been covered here heaps....
2. Leaks in lines... Check and re-new all vaccum lines, and other perished lines in the engine bay.
3. Crappy tune.
Check 1, if its ok, check 2, then check 3....
I get over 500kms a tank with full zorst, FMIC, 12psi and stock computer.... Well, should be better now I have the EMU installed
my car has full 3" turbo back exhaust 3" high flow cat, front mount intercooler, pod with cold air intake and grounded boost control solonoid running 10psi.
i get 420 - 450kms per tank on 98 octane city driving with the odd squirt here and there.....and that is without the fuel light coming on, i never let my fuel get that low.
high way driving, and city driving, well over 550kms.
like others hav said, change ur o2 sensor, plugs, and maybe try running 9psi to stop ur ecu running rich
goodluck !
i was driving aorund witht he fuel light on for a a while then was sitting in line at the servo so it was as good as dry as a bone
that fuel light can last upto 100km you know that right? :banana:
the best way to measure fuel economy is to do it as gtst said, or if you want to do it your way, drive around till it starts cutting out around corners (thats when its really low haha)
okay I will try changing the O2 sensor.
and also I will check whether there is leak along fuel line but I doubt it unless the dealer is really that mean
then I will try to check those vacuum.
if I have extra money maybe an Apexi Power FC like everyone does (isn't it expensive??? haha)
but thanks for those posters above.
Dude your fuel bill is way more expensive in the short run for you... Check all the mechanicals, then if still not getting any reasonable increases in economy get a computer. Apexi SAFC are cheap, Emanage are more expensive and heaps better, and PFC are great but really getting expensive.
  • 1 month later...
I changed my O2 sensor, then I bought those liquid to mix with fuel which helps in cleaning the fuel injector (I am not sure whether it works). I also changed the oil filter and engine oil.
the thing that concerns me is after changing the oxygen sensor, the mechanic used a scanner and plug in the plug under the driver's steering. He said the scanner detected no error code so the O2 sensor might not be the cause (unless it is running but getting lazy). He also said the sound is good and sound like no vacuum leak. He said the scanner cannot detect fuel injector so he sid could be that problem, or catalytic is blocked? then he told me to drive and sees how it goes.
my friend also used a "start ya" to check for vacuum leak and apparently no
the car goes with smooth boost too
now my first slot is just slightly more than 100kms.
do you guys reckon that is alright for an Automatic RB25DET?
do you think I should clean the AFM with Carbie Cleaner (I come across this method many times in this forum)
do you think I should change plug?
also the pod filter sound is quite loud... is it supposed to be like that?
I really seldom drive fast and is everything is stock except the aftermarket 3" exhaust (I didn't know it is aftermarket till my friend told me) and the pod filter.
could you guys list out more things before getting remap? because I doubt i have the money to get aftermarket ECU now, lol
eg what else to check...
  • 4 months later...
I just bought a lightly modified gts-t, 33, and have been doing a bit of fuel tests. Best i got was 10.5L/100Kms, on freeway. Worst i got was 13.2L, that was around city with fair bit of boosting.
Id say around 11.6L per 100Kms in on average my car fuel usage.
Mods i have is cooler, pod and cat back.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
