thatll be James
Crazy_J on the forums
i had my car as the bridal car at he's wedding :laugh:
ahk seen him the other night... never seen him before
theres another maroon 32 with black bonnet in melton that i see and i seen a black 34 for the first time aswell
saw a grey 33 on princes hwy in hallam and then he was behind me till fountain gate then dunno where he was.
also saw a r32 turn out onto princes hwy near nitro gym as i was waiting to do a u turn.
hey what color and what time because i came from HP from gf place slept over and got onto princess this morning to get to my pre apprenticeship this morning just got on time thought was running bit late, that could of been me the 32
Edited by BRUNSKIGTST
Just cruised down toorak rd/burwood hwy in my r32 to get some tyres fitted
Spotted:
B3ZA on burwood hwy near the BP
Black r32 with red/black advans and bomex front bar on toorak rd near tooronga rd - thought u were Karl, but he said he gave u the bar and rims :P
Another black r34 on burwood hwy near beaurepairs, didnt look my way.
Saw a black R33 at the Caroline Springs Carwash. RIght next to the CS Maccas and Petrol Station.
He pulled in booth nex to me, but didnt hav Sau sticker so wasnt sure if he is on SAU.
hey i think that was me. Was it about a week ago? cause last time i went there i dident see no skyline ... anyways hope to see you there agian next time we will chat
Spotted:
Black r32 with red/black advans and bomex front bar on toorak rd near tooronga rd - thought u were Karl, but he said he gave u the bar and rims :)
hey! i saw you and the 2 cars you saw aswell lol was on way home from uni!
tried catching upto you after it turned green for me but couldnt find you haha
i seen that black R34 few times on that road aswell.
Haha yeh I pulled into beaurepairs to pick up some wheels.
FINALLY SOMEONE SAW MY CARRRRRRRRRRRRRRRRRRR Yay :)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
