saw a black 32 in the lane next to me on belgrave hallam rd then u turned off at bout 3:20pm then saw a blue/green r33 at mobil with stickers down the door and then a marone r33 on james cook drive in e/hills on the nature strip
went running round dandy last night to meet ITZTRU and there's soooo many lines there... mostly shit lookin near stock + cheap chrome/altezza style 33's :)
edit: some nice line's @ creatd today tho :)
spotted not last night but the night before at approx 1am a silver/grey r33 doing a u-turn on mt.dandedong rd near the BP...saw you have a little fun in the wet..but was slightly worried as a police officer had driven past about 10seconds before you did your u-turn thought he might have seen you..
Spotted a Silver GTS-T R32 - plates UAV-XXX - around 4:15pm on the Monash Freeway, passing Forster Road (citybound). LPG on plates?? o.O
Spotted a Silver R34 - plates UFE-XXX - around 12:15am on the Monash Freeway, passing Forster Road (citybound).
Spotted a Silver R34 - plates XPNS1V - around 1:00am on the Calder Highway coming out of the BP servo just after Calder Park Race Way.
vls fail =P
ahhahaha so true my trainer at my pre app say its a crap shit box heap of a car, they always got problems , he knows he fixing his sister car had siezed brake calipars and we recoed the calipers,
Spoted a Blue R34 the other day on pound road at the lieghts heading towards FG
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
