hahahahaha ull never guess what i did..... i did a search on "itsab" and then when i returned no results i thought wtf maybe he spelled it wrong..... DOH! then i realised backwards Basti... idiot!
hello... my name is mr snrub... yes.. that'll do... and i think all the money should be donated to the town's local energy concern
spotted a White R33 with white rims (looked like 4door_gts' car but wasnt..) in the Ferntree gully maccas drive thru and infront of me in drive thru a black R32 with a massive NISMO sticker on the back.
saw a blue r34 on wellington rd. turned into monash next to me. same one i spotted a while back in the gym carpark. i'll say it again mate. that is NOT a gtr. neither is the silver 4door r34 that was waiting at teh bustop thing across the road. two very hot cars ruined by that wanna be badge
Spotted a black 33 on the NEWS!!!...
Lost his car for being 53km over the limit in the construction zone...
Let this be a lesson to everyone... ...The limit on the Monash is 60Km!!!...
Yeah I saw it to. Any body from here?
60km!! wtf? for cereal?
CEREAL!!!...
Any area where there are flashing lights it is down to 60km... ...I was on it a few weeks back coming out of the tunnel and it was down to 40km and only 2 lanes... ...but it was like 4am as well... ...so not so busy...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
