the other day on princess hwy, black r33 gtst s1 with ferrari emblem on front quarter and gtr badge on the back......seriously mate what the f*ck is goin on there?
LMAO people like that make me laugh
I once saw a gts-t V-Spec must be worth a fortune seeing as its the only one i have ever seen ahhahah
love how every monaro pulls up next to me wanting a go then backs off as soon as they hear the turbo spooling.... ahh the only advantage of having no air filtration at all :thumbsup: zzzzzzSSSSSSSSSSSSSSSSS
nice red r34 on sydney rd, nismo kit/gold rims
Edited by R-SPEC
Spotted a silver r32 on highstreet in melton
black r33 on highstreet in melton, down the westlake end, he gave me a stare then fluttered his blow off valve as he took off from the lights
spotted him again i think, about 20 mins later at the east maccas in melton
black 34 going down james cook drive in melton
May have been me, but i didnt go to maccas, itr wouldve been me if it had the big wing on the back. Could this be the first spotted for me??? hahaha. Dint mean to stare if i did, didnt see what you were driving, my platyes are 'siklin'
Edited by Damo_c
i've seen siklin in the past couple of days but i cant remember where. so yeah thats two spots for ya
didnt see the plates lol
i was in a white r34... it was at the lights near james cook drive on highstreet
I saw this r34 gtt last night completely covered with 'BURSONS' advertising!!
Does anyone know the car n wats up with it; the dude must own a shop franchise.
Im going for a drive now; they see me rollin' they hatin' ridin dirty'
AWD DRIFTING ?? hahah
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
