saw alot of skylines at RE today when dropping my car off lol
Dude... ...Finally back...
Will it still be there on Thursday???... ...I'm dropping mine in to have the timing belt loosened and tuned...
did you happen to see my car on the hoist ? hope so !
im guessing white stagea sau sticker on the window R34 GTT wheels???
if so nope it was parked outside under the tree.
all the hoists were full. they looked buy and was open till 6:30 today.
im only getting injectors done and a tune and i dont think it will be ready tomorrow
they looked busy so im guessing it would.
if you go its a white R34 GTT with gold intercooler pipes lol
spotted clean as white r32 gtr...IN2WIN parked undercover at HP today near the car wash..dunno if you saw my car but it was the gunmetal 32 gtst with gtr wing in front of...car looked mint
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
