what the hell r35 in hawaii . bet its those dudes in the army that stay there, always got nice cars (cardomin.com have heaps)
be kinda pointless there though, give it a bit of juice and you run out of road
Lol nah that should be the perfect place. Can tear it up on the wide open spaces of the army bases/airfields without cops.
SSpotted a few R33's and R34's and 1 R32 4 door yesterday night at the VSS cruise. was really good. also last night whilst on cruise drove past an R34 with the fast n furious paintjob. got the thumbs up
haha! that woulda been me! you in a stag?
awsome!
nah ment to be in the Stagea, but transmission in limp mode, so its at home.
Up here in a 08 Toyota Kluger. moved the miss's up for uni, saw you on the way back from KFC.
stagea should be up here in about a month
haha awesome. warrnambool KFC is the best ever.
off topic: i'd have to agree with you. oil is so clean! its almost healthy ! lol
might see you round, if i have better reaction you may get a toot from a massive 4wd !
spotted a blue R34 with sau stickers on the corner of lower dandy and warren rd, pretty sure it was R34PER, its the 2nd time i spotted you :P
i was just about to wave but my brain lagged coz i just woke up :)
Was meee, saw ya 2 buddy and ur last second wave....i waved 2 hehehee had a feelin was u and nearly in the same place ;)
oh and saw ya all at kamikaze, was parked between R3DLNE and NZMO mmm hot GTR!!
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
