Spoted BEZA! :) @ ABOUT 2am last night going right onto flinders st from hoddle st. Looked nice. I was my my mates black vx ss, which ran out of petrol on the way home lol. Some good exercise pushing that thing!
Edited by DRFT31
CRAP!! someone stole my CAR !!!!
ohwell they wont get far car has no reverse, and gearbox needs a rebuild. wasnt me mate, mines been parked up for the last 2weeks
ok now thats freaky lol
same car same darker R34 GTT wheels and and what looked like personalised plates. only assumed it would be you as i haven't seen any other stagea around that area or you g/f area. you have a twin brother out there TJ lol
LOL ouch
spotted a silver r33 s2 with gunmetal bbs meshies and gtr wing on princess highway yest. i thought it was my mate who has the exact same ride. was gonna pull up next to you and give you the finger, which i do to all my mates when i see them but i realised it was two large white dudes. hence the staring. thought you stole my mates car before i realised it was a r33, which are fkn eeeeeeverywhere
lol sorry man i saw ur guard liner dragging on the ground and i was like pffft sif not bolt it up thinking some random person
then wen i look up ur waving at me and by that time i drove past, i wouldve waved if i knew it was you earlier :D
Spotted KAZ180 on the Tulla Fwy the other day
what car are you driving? you seem to be around my area alot
spotted a black 33 on western ring rd heading to greensborough tonight about 6.45
spotted a black 33 coming up from southbank.. plates were.. suckin.. sakane.. something?
spotted a fluffy dice extravaganza that lives in the same building I park in.. kkyyky or something.. black 34.. white 34 on next level up..
oh spotted a yellow 34 in southbank tonight and a red 360 the other day near crown when i was on my way to lunch
and a grey 32 in thomastown sunday night I think.. drove past me and the doggies
^^ lol u always spot me man. actually now when i think about it i think i saw you yesterday as well. black series 2 but without te37s?
saw 2 32s today. one on the way home from uni from footscray. chick was driving a black 32 with some wide ass roh rims and a burgundy 32 with black stockies and kit in hoppers going down hogans road.
nah mine has TE37's...
I can't even remember what day I saw you, but if it was you, car looks good...black/dark wheels though, not your polished lip ones...so may have been someone else?
It's all good :D
The guard liner will be approapriately zip-tied when the cooler goes back on on Thursday :P
nah wouldn't have been me then. meisters are always on.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
