spotted few members of SAU in issue 75 of AUTOSALONN!! lol
i think i saw Bez leigh and Ashneel i think, dezz might of been in there too..only had a quick glance
as soon as i read that text i went and had to double check. SAU IN AUTOSALON MAG! :cheers: woo lol
Spotted a BLACK R32 GTR ( I think the number plate was MZTURBO or something close to it) on Sunshine Ave around 2-3pm
Then around 5pm ish Near That Auto shop at watergardens, it was a White 2dr R34 with GTR front and Carbon Fibre hood, LOOKS KOOL
Yeah buddy that was me haha, did u floor it after the lights when we ran?
Or where you just playing with me? hahaha
i cannot remember running you because i never went past vacume on my boost gauge lol.. if i did want to run u.. you would have noticed :D
was jst cruising along... dont remember flooring it after the lights either...
Hahahaa woohoo! two spots in one! MZTRBO was me :( and white r34 with the GTR front end was my old car
oh btw, were u the black four-door with diff rims on each side? u then turned off into the carwash and were washing ur car.
I was with my friend in the car we seen u turn onto sunshine ave and were both like at the same time 'the rims on that four-door look hot what are they?', then we caught up to you and the rims on the otherside were different lol
It's all the rage now. Haven't you heard?
As long as the tyres, offset, and diameter were all the same on all four I don't see why there would be a problem with having different rims on either side... ...Put a black set on the right side and a silver set on the left...
It'd be a lot easier to tell who ripped you off too...
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
