spotted few members of SAU in issue 75 of AUTOSALONN!! lol
i think i saw Bez leigh and Ashneel i think, dezz might of been in there too..only had a quick glance
as soon as i read that text i went and had to double check. SAU IN AUTOSALON MAG! :cheers: woo lol
Spotted a BLACK R32 GTR ( I think the number plate was MZTURBO or something close to it) on Sunshine Ave around 2-3pm
Then around 5pm ish Near That Auto shop at watergardens, it was a White 2dr R34 with GTR front and Carbon Fibre hood, LOOKS KOOL
Yeah buddy that was me haha, did u floor it after the lights when we ran?
Or where you just playing with me? hahaha
i cannot remember running you because i never went past vacume on my boost gauge lol.. if i did want to run u.. you would have noticed :D
was jst cruising along... dont remember flooring it after the lights either...
Hahahaa woohoo! two spots in one! MZTRBO was me :( and white r34 with the GTR front end was my old car
oh btw, were u the black four-door with diff rims on each side? u then turned off into the carwash and were washing ur car.
I was with my friend in the car we seen u turn onto sunshine ave and were both like at the same time 'the rims on that four-door look hot what are they?', then we caught up to you and the rims on the otherside were different lol
It's all the rage now. Haven't you heard?
As long as the tyres, offset, and diameter were all the same on all four I don't see why there would be a problem with having different rims on either side... ...Put a black set on the right side and a silver set on the left...
It'd be a lot easier to tell who ripped you off too...
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
