You talking about Jeremy Leigh? That little pulsar can shit over half the skylines
I don't know probably, didn't shit over me or anything but kept up thats for sure!
LOL Bez I didn't see you in it?
Spotted Harsh In his daily on pound rd this morning :D
hahaha...i see you almost everyday now...today you rocked up to the intersection a bit earlier than yesterday...lol...otherwise i see on the freeway driving past just before pound road exit...lol....
you wont see me tomorrow, I have to get off an exit b4 pound rd to go into dande to get a mate whos dropping off his car for service
HAHAHA!!! funny i was going to tell you the same thing...will be going to work early so i can finish early and look at some houses with mrs...lol..well dont u worry ill spot you soon...not hard to miss a 32 gtr driving past on the freeway...its like MUSIC TO EARS!!!!..lol...
Ha yeh but its easy to miss your vn/vp/vs? falcodore. I just keep an eye out as I come off the off ramp to see if your about
hahaha...true true...is a vp comodoRE..lol...all i do is drive and if i spot a skyline i look and it always happenes to be a 32 gtr driving past on the other side of the freeway around the same time ish...so i just guess its just you...lol...
White R33 with pink custom plates BR*GAL (I didn't get a good look) leaving a 7-11 on Punt rd around 3:15
Also saw a car that looked like REDL1N on the Eastern heading away from the city around 3
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
