I'm currently looking at a full R32 GTR interior.
My question is, would this be compatible with an R32 GTST 4 door sedan?
I want to convert the dash and electrics, door trims seats etc..
Would this be a pheasible conversion or an impossibility?
Anyone got any advice???
I've searched the forum, but can't find anything on this conversion of stuff like the dash itself and instrument cluster.
Thanks for your help people!!!
https://www.sau.com.au/forums/topic/21053-r32-gtr-interior-to-r32-gtst-4-door/
dash, front seats and rails should see you swapping em comfortably, altho I dunno why you'd wanna swap the dash.
The rear seat and the mounts in the 4 door are different to the 2 doors, so unless you got a lot of time, a welder and a bit of fibreglass I wouldn't bother... besides, the 4 door back seat is a lot more comfy than a 2 door. 2 door backseat should be called shopping bag tray... that's how tiny it is.
f you want the best looks for the 4 door, hunt down a R32 GTSt Type S 4 door (yes they exist), it has GTR spec steering wheel, dash, console, center accessory holder (the bit between the two front seats), GTR trim front and rear back seat (same shape as a GTSt tho, the front seats are a bit curvier).
I probably wouldn't swap the dash itself! Bit too problamatic! I want to swap the dash instrument cluster over (sorry should've been clearer). I think the GTR instruments are a straight swap over to the GTST aren't they? You get a un-working torque gauge, but apart from that it's all fine I think...
Humph :)
It seems that ANY 4 door R32 seems to be hard to find if you don't live in Japan or New Zealand :(:P
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
