  • Replies 171
Posted Images
bin asked to give directions to deakin. from the meet point, its North up warrigal rd, turn right on burwood, left immediatly after the hungry's (elgar rd?) and right at the first lights.
if you're coming down dandenong rd, take waverly rd (left) and you should eventually get to warrigal. the meet point is there. just follow us from there.
map 4 nick
thats deakin
map 4 nick
thats deakin
What happened to Chaddy?!!!!!!!!!!!!!!!!!!!!!!!!
I'm going to be a Dez on this one and say that its too far!! We might have 2 catch u all @ the glen
map 4 nick
thats deakin
Correct. Two entrances, one off Elgar Rd and the other off Burwood Hwy a bit past Elgar Rd.
Easy to get to.
OK PEEPS THE MEET IS AT 8:30 THURSDAY!!!
so i am going to wash my ride BEFORE THE MEET at around 7:45pm at NOBLE PARK ( the ghetto ) CAR WASH at the SAFEWAY petrol station on princess hwy opposite RACV
pre meet maybe?
then we can make our way to the ''MEET N GREET''
PS: you dont have to ask if you can come to the car wash!! just throw up a post saying " I AM DOWN FOR THE CAR WASH''
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
