i just saw a rex with RUT MTD....i had a bloody hard time figuring it out driving behind it for a while. is it R U tempted?
another one is I8ROX....is it I ate rocks?
these custom plates give me headaches.
I8ROX = Ibrox
Glasgow Rangers home stadium. what a champ :D
  • Replies 86
a mate has SIR 32 on his r32 obviously....
also seen
BOOAST....mate has that on his 33....
on a pimped 300c chrysler...black with massive chromies plate was PAY ME
mate with a real estated business has seven cars.....top of line stuff....ferrari, masserati, merc, bmw...hsa the cars labelled T1, T2 etc....
a mate of mine used to have "an4lxs" on his n13, they wernt custom, just your bog stock nsw plates.
also spotted "clitoris" on a monaro i think it was parked outside a sex shop a few weeks ago.
theres also "s3xed" which apparently is meant to mean sex ed, not sexed..
hahaha joels old plates on his svd :lol:
i seen
TIT-53X (tit sex) supra
DRY-53X, e36 bmw
ICU-45X ( i see u for sex) 200sx
UP4-BJS ( up for blowjobs) old corolla
BJB-45X (blowjob before sex) exa
MRNEMO ( was a mates lancer with Nemo airbrushing)
D3ADLY (deadly) on an astina lol
XXX-53X (xxx sex) rusted vl
theres more im sure, wollongong had some top plates lol
Edited by 2BNVS
mate has IOUFN on his monaro.... I owe you f*kin nothing
have seen 2 people on boost?? maybe and theres were hsvsuk and wrxsuk...........think they are both mates haha
Why would an audi have plates saying WRX sux ? shouldnt be Bmw sux or something along those lines
probably because audi has quattro and pwns WRX.
Ive seen some shockers too... NOTDADS on a beat up old black 735i - must have been a 1984 model? I remember exhaust technology had a sky blue TX-3 4wd laser with JUSTTRY on it. I remember seeing someone with the plates WIFEBTR on it, lol.
Personally id like to get the plate GAIJIN.
Recently saw a poofy Supra in Parramatta with "CUNBED" :D so cheesy.
Saw an Audi A4 on King Georges Rd recently with "MR NSW", the guy looked like Fabio with self esteem issues :)
Also my mate told me ages ago he saw an Integra or a Rexy with "OMAR" plates. Hey...that's my name. Who the hell names their car their own name? WTF? Maybe the dude had a pencil case stolen at school and never got over it :)
Or maybe there's so many of those bombs you'd lose it in a car park :cheers:
Edited by R338OY
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
