  • Replies 40
I don't mean to be rude, but it's kinda simple really.
Can't afford to maintain a car, don't modify it. Can't do the work yourself, you have to pay for it. Can't afford to pay for it, don't modify it, maintain it. Can't afford to maintain it........
Vicious cycle really.
What they all said... :no:
Thats a cheap fair price dont be tight...
Best thing i can suggest which is cheaper than Re Customs is call Nissan Australia im sure they will be happy to help you out...
For a fair price.
Farkk man i was told mechanics are negotiable, i didnt know how much it cost for a turbo swap so seriously how was i supposed to know that was a good price? I dont really care if it cost me $500 i wouldve paid it ive got the money i was just saying... talk about going overboard.. banning for that? pfft
Banjo fitting on the left, Banjo bolt that goes through it on the right
HIS Hose can do the fittings for you.
If you look through the forums (probably the general mechanical section or whatever it is), you'll find heaps of info on doing it yourself, but if you have no idea what you're doing, then probably just easier to get Ray at RE to do it for you :P
Woah, joke relax :)
lol my bad wasnt sure if u were joking on not :cheers:
If you look through the forums (probably the general mechanical section or whatever it is), you'll find heaps of info on doing it yourself, but if you have no idea what you're doing, then probably just easier to get Ray at RE to do it for you :)
Ahhh yeah that would be it.. Yeah really i'd do it myself even if it took 2 days but thats if i knew how to do it... I only got my skyline about 4 months ago and havent done much when it comes to mechanical work so im still learning everything as i go.. Hopefully in the future ill be more confident and know what things are and do it myself =] but until then i'll be going to RE lol
Yeah I don't personally think a turbo is something you want to attempt with little experience, before I had my Skylines I was kinda the same and I did things like oil coolers and intercoolers but a turbo is pretty serious stuff, don't want it going bang and it's a bit of a bitch of a job for a n00b :cheers:
Sounds good sounds good =] $550 (extra $200 for the water lines/banjo fitments) .. cant wait to get some power man stock car driving me crazy its so slow
Have you done the basics, before turbo?
- ecu
- fmic
- fuel pump
- etc
If not scrap the turbo idea and do the above first, these will unleash the full potential of your current setup and for the turbo upgrade later. Without doing the above, you'll be VERY limited in the power increase.
PS: Hope you're not buying some cheap shit China turbo or a truck turbo :P
That would be a waste of your money and Ray's time.
- ecu
- fmic
- fuel pump
- etc
PS: Hope you're not buying some cheap shit China turbo or a truck turbo :/
I have a hooooooooooooge ETC on my car.. its awesome! :D
^^ i may not know alot car's but im not an idiot lol im not gonna buy like a turbo off eBay.. heres the shopping list so far im trying to keep it at 5K for new upgrades so im thinking just add the AVCR (takes me to 4.15K) and keep the rest for the re-map/dyno time.
Front Mount Intercooler - Done
3" Catback Exhaust - Done
Turbotech Bleed Valve - Done
Stock Airbox - $150
Garrett GT28RS w/ T3 Flange - $1795
X-Force 3" High-Flow Cat - $199
JJR 3" Dump/Front Pipe - $269
GTR Injectors + Resistors + Cleaned - $600
Installation - Turbo $550
Installation - Injectors $?
Undecided: Dr. Drift/HPF/CEF11E Re-Map $?
Undecided: Tomei Cam Gears In+Ex - $365
Undecided: Apexi AVCR $580
Undecided: Apexi ECV $230
Total - $3563 without Undecided items or Injectors Installation
Edited by cosmokram3r
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
