Anybody have any idea what the differences are between rb26 blocks.
Ok we know r34 is better made, but not all that much in it between them.
eg could one take an r32 block, use an r33 crank, and r34 head, etc and make it all work or are there actual differences ?
Just thinking i think the oil pump chanels are different ?
E
same blocks,
r33 and r34 run different nose on the crank from r32 and different oil pump,other than that there the same.
u can interchange all components,provided u use the right oil pump to match the crank or u can run an adapter on r32 crank to use later pump.
I have heard that the N1 block is different and supposed to be somehow "better", but as far as I know all the other RB26 blocks are the same.
I believe the same block casting is also used in the RB25 AWD engines used in the R33 GTS-4, and the R34 RB25DET neo used in the Stagea.
All these engines use the alloy 4WD sump, and have the special pan rails.
  • 9 years later...
bump. 10 years later.
I have a couple of questions and I don't want to start a new thread:
1) Can a r32 N1 block fit into a 34-R?
2) Does the 34-R RB26 have stronger internals, CAMs, or other machine components than a 32-R engine? I'm not talking about differences in sensors or other electronics as I'm aware about the coils, CAS, etc.
3) Do 32-R N1 engines have better/same turbo chargers as a 34-R block?
1. Yes. Identical
2. Not really. Just the better drive for the oil pump, about it.
3. No. They have shitty lag fest turbos. 34N1 are basically the same as Garrett -7s, best for response and around 300-320rwkw
End of the day N1 factory blocks have not proven to be stronger than a normal 26 block. N1s just cost more yet still retaining the oiling issues with poor returns and no restrictors in the blocks. So in summary, they are a waste of money - better of rebuilding in todays day and age
Thanks again, mate. :-)
So with question1, there's no issues with a 32-R N1 block fitting into the R34 ATESSA, tranny, etc?
2. Whats the difference between a 32-R N1 and 34-R Nur (N1 engine from what I read)?
The N1 RB26DETT's were all the same but,
The R33 N1 RB26's turbos and engine were slightly revised.
The R34 N1 RB26 was further revised with the Camshaft Timing altered for more torque.
R34 GTR N1 Turbos are Ball Bearing hence allowing the shaft to spin faster = More responsive.
R33 N1 turbo's IIRC were still larger than R34 N1s as they make more power but are noticeably less responsive
1. As i said, it's identical. This means no problems.
2. Again as i said crank snount for the oil drive, turbos and honestly - fk all else. N1/NUR motors still have the inherent flaws that any decent rebuild should well and truly fix.
They are very similar but if larger, they are not by much.
R33 N1 Turbine Wheel = 41.7mm - 53.0mm
R34 N1 Turbine Wheel = 42.4mm - 53.8mm
R33 N1 Turbine Trim = CD79
R34 N1 Turbine Trim = 62T
Edited my post anyway :)
Also I believe the N1 Block is reinforced.
Yeah exhaust wheel isn't the only factor - comp wheel also
Ye N1 block has extra ribbing - but people have split them @ the same levels as normal ones. So it's not really a set in stone "advantage" even @ 400rwkw.
Yeah for sure, I should have listed that too:
R33 N1 Compressor Wheel = 44.5mm - 60.1mm
R34 N1 Compressor Wheel = 44.5mm - 60.0mm
I am sure for a street application, it's fine.
Might have to go for a Nismo RRR Black (GT500) :D
  • 5 years later...
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
