Hey guys,
Well after going to the drift practise friday night and seeing several cars getting around with strobe lights in the headlights with cop style flash patterns...
does anyone know where i can get these???
where u located man? I think autojoy in sydney had them..but i dunno...
Blitz i-Burner Spark lights.Look on the Blitz website.
You do know these are illegal to have on the road right??
I got a quote for the Blitz strobes from Greenline a while ago, $260 delivered to Victoria.
so are these real headlights bulbs that flashes as well?
I know the jaycar kit fits nice in the foglight or indicator slot on a S2 R33 with some strong adhesive tape.
Edited by POLICE
sooner or later someone is gonna recommend you talk to me.
Alot of people saw my D1 style strobe lights at AutoSalon Final battle.
The lights i used are from jaycar. They cost $29.95 for the set and takes bout 5 mins to install.
I figured fog lights were illegal so i removed mine and but the strobe globes inside, then put the cap back on.
all you gotta do is run the wires into cabin though firewall, connect to 12V power (either constant so you can run them without the car being on, or accessory power) and then connect to ground.
I located the contoller box in my glove box. it has a few functions
- single flash together
- single flash seperate
- triple flash together
- triple flash seperate
then there is a variable speed contoll.
Any more questions, feel free to ask me. its easy as ABC or 123??
Paul 0403 954 613
Hmm sounds pretty simple and easy, hell for $30 i might aswell give it a shot, should be funny for a nights worth of entertainment lol.
So they are an actual replacement bulb? I thought it was more of a thing you could install on your own bulbs. Anyone got a pic of the kit? Had a look on Jaycars website but can't seem to find it.
Edited by PM-R33
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
