haha. No worries :) That list gets updated everytime I get another form through. We are filling up very quickly :D I get the feeling that the next event will have to be a 2day event.
You missed my question :D
So if you dont send a EOI form in you could miss out on a spot??
  • Replies 1.9k
Sorry about that I did see your question then the phone rang sorry. If we fill up the list then yes you proberly will miss out. You are better off filling it out if you are interested then once the Official Entry Form comes out you decide you are not interested let us know as I am sure we will be able to fill the spot.
CHeers
-Nathan
CHeers
-Nathan
Thanks for clearing that up..I will send in a form
Would changing class be a problem later on? If I said Street on the EOI form but then want to go in Open class...
Even better!
Can i send you an EOI form for that one aswel? ;)
It would be nice to see a definitive list of tyres for both classes, no ambiguity,
so clueless people like me know what to source. :D
Wayne? :) I am not in the office but off the top of my head for Clubsprint Class I think your best options will be :
Yokohama - AVS Sport
Bridgestone - RE070A, RE-01R
Falken - RT615, RT215
Federal - 595RS
Toyo - R1R
Michelin - Direzza Sport Z1
Dunlop - Pilot Sport PS2
Have I missed any Andrew?
Cheers
-Nathan
fantastic to see it finally going ahead. Events in other states ftw. Are they all going to be Cams ran events, or is that just becuase cams are Oran Park?
I would like a middle class there where the non-workshop cars with semis can battle it out...
Street
Super Street
Open
something like that would be good to keep in mind for future.
everyone always likes to have an idea in their mind they can at least be competitive in their class...
:down:
I'm entered!!
Should be fun in the little Lotus.
Maybe I can put it in the boot of Loftys BSM GTR.
My BSM GTR is still FOR SALE and can be delivered to its new owner in time for this event :)
EOI sent.
Is it ok to use Yoko AO 48's in the open class.
Also I havbe suggested braking up the awards into capacity and drive as aposed to cylinders and drive. This gives people with a rb20 a chance instad of them bieng up against and R33 or a 300ZX.
Cheers
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
