  • Replies 1.9k
this is awsome
your all fags!
Luv the fats curve balls.
Re aero yes made an alloy rear under tray from in front of the diff back and rear diffuser with director plates and 4 small vortex generators under the car at the leading edge of diffuser, for less drag, and keep air attached to the high sloping rear diffuser for more down force. Also cut out rear bar a bit to let air out form rear wheels and air ducted at the diff for cooling. Also cut bottom few inches of rear bar for better transition of air leaving the car and will be adding VG's under there also.
Front, we made a Carbon Kevlar under tray with air dam 50mm tapered up rise and has trip strips ( not in pic) in front of the wheels and along the edge of air dam to prevent turbulence form the wheels and help air dam work better. Also made a front splitter with FRP and adjustable supports.
See here for more.
Slot Car Link
We also cut away bottom of the guards behind front wheels to let air out, removed plastic splash guards under the front guards, and opened up the holes leading into the rear of the engine bay to help air to exit. We also pumped the guards out a bit to help air out but need to support this as I noticed it shaking down the straight, and pump it a bit more to help more air get out.
Hey Dirtgarage that Olive branch has got thorns on it. For someone trying to start a business of some sort you are digging a hole for yourself you are throwing so much dirt, and stop digging up guff.
John, give it a rest now mate.
I have spoken to Paul and now im speaking to you, if you two want to bicker/argue/fondle each other, do it off the forum.
Thanks.
Looks shit.
And by that I mean it looks awesome.
Where's the second exhaust that the 300s normally have? I think I've missed something obvious here... It's not running an RB is it? :P
Real Z32's run RB26's, this is a documented and well known fact :)
Thanks for the info and the link, that's great.
Why are the front splitter supports adjustable? Do you run the front splitter at an angle?
Have you noticed much difference?
Why would I run a less reliable motor and hang more cylinders over the front of cross member? It has a lot of gtr parts including in the engine but I would never ptu an RB in it. waiting...... We are working on a VQ30 which will be a 3.8 litre adn alloy block and 210kg compared to VG30DETT 310kg.
Adjustable to get on trailer easier as I wind it up and yes for track depends on the track I can wind it lower and get slight more angle. Definitely noticed the difference and the main to only change I did when I went back to Philip Island last year in October, as I was there pre splitter and air dam in Easter, and I noticed much more down force on the front, and yes Ican feel it. I actuall needed to remove the front Carbon fibre Kennard’s in testing on the Sat prior to timed event on the Sunday to balance the car out.
Next we will be making some GT 500 style rack off side skirts and looking at doing some rear aero on side of rear bar, like the German touring cars.
Maybe I should just buy Russ and Marks R32 GTR… Hmmm I like a challenge though.
310kg John? wow, that's heavy isn't it (in absolute terms). How does that compare to an RB26? And I hear you re extra engine hangin out in the breeze. I've always wanted to either SR an R32 gts (yes, I'm sick), or VQ a GTR.
RB26 not much lighter you will find if any?
Nissan smartened up and did this and put an alloy V6 in the new R35 GTR.
People often ask why I don't race a GTR. RB26 fans don't read this below.................................
Just to compare the VG30DETT which has not come out of the car for three years, has done zillion track days and this one makes up to 438rwkw has stock, block and crank, water pump, oil pump, sump other than little plate we Tig weld in to stop oil flying out of the well, stock manifolds, throttle bodies and plenum. Much more reliable and cheaper than RB26 with similar power for track use.
yeah but when was the last time they took the engine out of the QEII?
you made the correct engine choice for a nautical application JP.
:D :D :bunny:
Edited by wolverine
Wow have I missed some crap on this thread over the last few days LOL
Have just spent the last few days at Lakeside raceway........I thought they were going to spend money on the track :P
Looking at the stuff that has been written....I was wondering if this is still a superlap thread??
I would certainly like to have a response from superlap on the thread. C'mon Ian and Nathan, I am sure you have caught up on sleep :D
Have just spent the last few days at Lakeside raceway........I thought they were going to spend money on the track :D
I would certainly like to have a response from superlap on the thread. C'mon Ian and Nathan, I am sure you have caught up on sleep :banana:
Lots of good reading on here with all the bitching ,this page is not about racing its more about throwing shit on each other lets just hire a boxing ring and sort it all out ,there will be more people there to watch then super lap , so which pro fighter would you use John i dont think bozo could enter that one for you :P
Now there's an intelligent man! :P
John: Top idea to make it easier to get on the trailer, wouldn't have thought of that. I'll be keen to see updates as I want to get some undertrays on my car soonish
You need to understand that i have just finished building a bitumen facility. So that means i have MEANS. Talk like that gives me MOTIVE for a good tar and feathering! :D
LOL, sadly i think the same thing very often, in fact recently asked a friend to follow up with some enquiries concerning such an animal :)
Have just spent the last few days at Lakeside raceway........I thought they were going to spend money on the track :)
I would certainly like to have a response from superlap on the thread. C'mon Ian and Nathan, I am sure you have caught up on sleep :)
Hi John, on a side note re Lakeside, just had your friend and my neighbour Mr Dawson in my warehouse outlining the plans Tettley has to iron out the kink in Lakeside's main straight later in the year amongst other things. That is a travesty! :D
oh yeah. if things go our way big boy we can enter it next years super lap. doesn't matter who buys it, me or you. but either way we both get a steer.
looks like a GTST. mmm motec.
wha? :)
marlin re animal see above! 2.2litre, built at prime garage. all the usual good bits. supposedly a very quick track car and quite light. the current owner still drives it on the road too! got to love japan.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
