  • Replies 745
you can;t really knock off a company just because of one bad experience, and if the company is not up to standard it doesn;t mean that you can;t get better elsewhere locally. Like dan said i would like to see you get service like what shauno got from Ozgiken. Sometimes you have wonder is the japanese stuff worth it as they usually cost more than locally manifactured stuff. sometimes it may be worth it sometimes not.
Jay have you seen the stuff on Unique Autosports at the moment... there are a set of Yokohama Wets for $290 in 17"... they look sweet... few race seats and stuff... oh... and one for me a Veilside 2pc front bar for a S13 silvia.... I'm getting my credit card out already... :rofl: just kidding...
Yeah but we're both pimping in the 18" crew :)
Hey talking of the end of August is anyone racing at Benaraby in the mid august... what is the exact dates again??
I would be keen but I haven't done a single thing to the Silvia so I might just save my money until my cooler kit gets here... Actually Jay I was thinking that after the cooler kit I should get one of those nice polished exhaust manifolds you were talking about... Polished piping... I could be pimping too....
Actually you should check out www.sarukaauto.com.au/current.htm
I have a friend that loves starlets... she wanted a turbo rig so can anyone find any cheap ones for sale... neat stockers probably would be the best.... and preferably red... she loves red... So tell me what sort of prices she should look for??
talking of that... who has High Octane 4... and why haven't we got it??
cause theres a shortage of it .... tried to buy a copy the other day and no one in rocky has any in stock. autospeed are about the only place on the net that still has stock.
Willo have a look at www.aablatch.com.au/daikin.shtml
they might have something you can use... that clutch on the top of their page looks like it could take just a little bit of abuse...
Maybe see if you can find which one you like best and then call in squizz to do some cut-throat bargining...
Hey shaun do Nicks do a twin plate or anything of the kind...
whats wrong with exedy clutches - their japanese though ..... www.exedy.co.jp
centreforce - american though - www.centerforce.com
then you've got osgiken .... i can;t find any websites for ozzy made clutches. either they don't advertise with search engines or they don't have websites ....
Hey matt are any of your team headed down the drags to the test and tune... has anyone talked Rick into it yet?? Dev seems pretty keen so that should be good to see... I don't know about wiether to race or not... maybe if Jay races... or pete... that sounds like alot of work getting pete's car going again though... although mad mountain runs are go... Jay is going to show us why four doors are more balanced than two... hell I seen the sideways action last night... don't tell me you weren't flying cause I was going and I saw your headlights the whole way up... actually I think I touched over 140 at one point... not that we encourage that sort of behaviour....
actually I am bulk impressed with the Scibyline... It goes hard... He called me from the lap and within a couple of minutes he was at the top of the Mount... and he lead the way down... if it wasn't for that damn S12... but he did keep us all on the safe side... I actually like going up rather than down... it feels more controlled...
anyway... that is me for the day... time for some Bersy Lunch...
have fun guys...
and stay safe...
That clutch at the top of the page looks exactly the same as the Nismo one I bought. It uses a strap system which has been superseded and you can't get clutch plates for it any more. The closest plates don't fit properly and are $400 a piece.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
